ISDN failover for DSL
timoconnell
I have installed a DSL router(837) in 3 of our sites which previously had ISDN, ISDN is being kept as backup. I have configured the routers with HSRP & we are tracking ATM0. eigrp is used. All works well until there is a problem with the DSL service. The link does not failover to ISDN until the DSL router is switched off. It then reverts to ISDN. Anyone got a sample config of this type of failover. Even though the DSL service is down, ATM0 musn't be dropping.
Hope someone can help,
Tim
mheusinger
Level 10
Level 10
the feature which should help you is called "object tracking". It allows to modify routing based on the availability of an "object", which can be f.e. ICMP reachability of a host. For a detailed explanation please have a look at "Configuring Enhanced Object Tracking"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fbeb.html
Hope this helps! Please rate all posts.
Regards, Martin
