isdn issue
pritishkemal
i have bri connectivity which is configured using dialer. the configuration is given below. according to the configuration second bri channel should go up when there more data transfer. that is working fine. the problem is when ther is less data transfer. the channel waits till the idle time out period. channel two goes down .at the same time channel one also goes down and comes up.at this moment i am able to ping my remote router .but i am not able to ping from my pc . i get four request time outs what is the reson for this. the config is given below
boot-start-marker
boot system flash c1841-ipbase-mz.124-1c.bin
boot system flash c1841-advipservicesk9-mz.124-12.bin
boot-end-marker
no aaa new-model
ip cef
isdn switch-type basic-net3
interface Loopback1
ip address 172.16.100.5 255.255.255.240
interface FastEthernet0/0
ip address x.x.x.x x.x.x.x
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn point-to-point-setup
ppp authentication chap
ppp multilink
interface Dialer1
ip unnumbered Loopback1
encapsulation ppp
dialer pool 1
dialer remote-name cdac1
dialer idle-timeout 20
dialer string xxxxxxx
dialer load-threshold 5 outbound
dialer-group 1
ppp multilink
interface Dialer2
no ip address
shutdown
interface Dialer3
no ip address
shutdown
ip route 192.168.40.80 255.255.255.240 Dialer1
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
password <removed>
login local
line aux 0
line vty 0 4
privilege level 15
login local
scheduler allocate 20000 1000
end
second router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
interface Loopback1
ip address 172.16.100.4 255.255.255.240
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
no ip address
encapsulation ppp
ppp multilink
interface Dialer1
encapsulation ppp
dialer pool 1
dialer remote-name xxxx
dialer string 2313282
dialer-group 1
ppp multilink
ip route x.x.x.x x.x.x.xDialer1
no ip http server
control-plane
line con 0
password <removed>
login local
line aux 0
line vty 0 4
privilege level 15
login local
Wilson Samuel
Level 7
Level 7
Please correct me if I'm missing something, as far as I understand, the issue is that you are able to ping from your router but not from your pc the moment BRI comes down?
That means that the router dials whenever you are pinging from the router however it doesnt whenever you ping from your pc?
Why not try to do a continous ping from PC?
Kind Regards,
Wilson Samuel
PS: Please rate if it helps
A continuous ping is already there. i will tell the actual requirement and problem.
the customer wants the bri second channe to go up only when there is alarge data transfer.that is working fine . the problem is when there is less data tansfer after a large data transfer. according to the config channel two goes down .that is fine.at same moment channel one also goes down and comes up.why this happens . because there is still data transfer ie i have given a continuous ping with 32 bytes. channel one is not supposed to go down even it is for one second.why is that happening.this is what the customer wants to know.
spremkumar
Level 9
Level 9
hi
is there any specific reason behind configuring isdn point-to-point-setup under the bri interface ?
can you remove the same on both the ends and check out for the results?
regds
