ISDN Module NM-8B-S/T and Router 2921 Compatibility
limlayhin
Hi All,
I am planning to do Tech Refresh on my existing Cisco 2621XM router.
The router has NM-8B-S/T - 8 Ports ISDN BRI modules.
The new router will be 2921.
Can I fit NM-8B-S/T from Cisco 2621XM into new Cisco 2921 router?
Thanks all for the help.
Show diag of current router:
Slot 1:
        BRI (S/T) Port adapter, 8 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware revision 1.0           Board revision E0
        Serial number     31742540      Part number    800-01237-03
        FRU Part Number:  NM-8B-S/T=
        Test history      0x0           RMA number     00-00-00
        EEPROM format version 1
        EEPROM contents (hex):
          0x00: 01 21 01 00 01 E4 5A 4C 50 04 D5 03 00 00 00 00
          0x10: 70 00 00 00 04 02 13 17 FF FF FF FF FF FF FF FF
Leo Laohoo
Won't work.
The replacement part is HWIC-4B-S/T.
