ISP connection
newIntern
Frequent Visitor
Frequent Visitor
I received the mission to explore the possibility of replacing the ISP's router (it's been crashing) with a CISCO 3925 (I know... absolute). The ISP router has a WAN interface and other LAN interfaces that I can connect to firewalls. The ISP makes a subnet (/29) available to us, which we use for firewalls and other equipment. The connection with the ISP via pppoe is simple and I already did it but after realizing that the other interfaces of the 3925 are also WAN, but I have to keep the public IPs on the firewalls and other WAN interfaces cannot have an IP of the same range as the interface connected to the ISP. I'm out of ideas.
11 Replies 11
I try to get what you want here I could not, can you more elaborate ?
O attached a picture of what I wrote in the post.
why you use router if you want FW use public IP ? that I can not understand.
if you dont have SW then
the FW if using HA then you can config the router as IRB
https://community.cisco.com/t5/network-management/two-firewall-to-one-router/m-p/4741011
balaji.bandi
What version of Code running on Router, you can use bridge mode to retain Public IP extended to Lan side
configure access port or trunk port on switch to extend the VLAN to FW
is that works for you ?
BB
Thanks for the repply.
Right now I can not say the version of the software. I Will check it on monday.
I did not understand every aspect of your idea.
Was your idea based on the picture I attached in the post?
Thanks.
yes correct, if you like to have Public IP on FW you need configure bridge mode ?
BB
Hello
@newIntern wrote:
I have to keep the public IPs on the firewalls and other WAN interfaces -cannot have an IP of the same range as the interface connected to the ISP. I'm out of ideas.
Looking at your diagram you need to bridge the two interfaces on the wan rtr as such the fws will be able to retain their ip addressing.
bridge 1 protocol ieee
bridge 1 route ip
bridge irb
int x/x
Description WAN
no ip address
bridge-group 1
int x/x
Description LAN
no ip address
bridge-group 1
int bvi 1
ip address x.x.x.1 255.255.255.248
Just in case the rtr doesn't support IRB, you could use BDI
int x/x
Description WAN
service instance 1 ethernet
encapsulation dot1q 1
bridge-domain 1
int x/x
Description LAN
bridge-domain 1
interface BDI1
Kind Regards
Paul
Ok thanks. I understood this config.
But how do I connect to the ISP? Should I use PPPoE on the interface facing the ISP? Can BVI interface be configured with PPPoE? Or should I set an IP address, that can talk to the ISP, on the BVI interface?
There is any other options that works?
Thanks a lot.
I spoke to my ISP and they only connect via PPPoE.
Let do some summary'
-Fw HA not support pppoe
- router can NATing so you can do NATing for public IP connect to router to FW OUTside interface
That only what you need no need any more PPPoE for BVI of router.
Thanks for the repply,
I understand that my questions seem meaningless taking into account that it was enough that the connection to the isp was pppoe, the connection of the router to the firewalls was in a private network range (ex. 192.168.2.0/30) and the router would be configured nat for IP public, VPNs would be configured on the router as well.
But the problem is that they don't want to change the settings of the firewalls that have many VPNs and other things that only having a public ip in their interface would be possible. And I don't have much to do about it.
That said, with my post I try to find a solution that meets what I was asked and that I tried to convey in the photo that I attached to the post.
OBS: By the way, the firewalls are in HA so I put a switch there.
So my question remains and boils down to:
1-I can do it by configuring a bridge on the 3925 router (it supports IRB, BVI, ...)
2-Since ISP only provides PPPoE, in which interface should I configure this, BVI or physical that is facing ISP? The other thing else I should do?
OBS: the solution must take into account the scheme of what I want this in the initial post.
Thank you very much.
