ISP DHCP + ASA5505 = no ip
rwagner
The title says it all.
I have an ASA5505 connected to a residential ISP provider.  I configured the WAN port as a DHCP client.  The ASA recieved no IP address from the ISP.
I then put in a netgear router as my border device and configured the WAN port as a DHCP client.  It recieved a IP address from the ISP.  Then I configured the LAN port with a DHCP server and connected the ASA WAN port directly to the netgear LAN.  The ASA recieved the IP address from the netgear router.
I would like to remove the netgear router and put the ASA as my border device, but the ISP (comcast) residential support people are pretty much useless.
NOTE:  I will double check my current ASA IOS, but i am aware of the version update for 7.2.(2).22 and how the ASA wasn't sending a client-id.  I already did that update and set the client-id for the ASA mac-address.  That didn't resolve the issue.
rtjensen4
Level 4
Level 4
You might have to call your ISP and have them release your IP... some ISPs only alot you 1 DHCP address with a relatively annoying lease timeout. You can probably wait for it to timeout by having NOTHING attached for a while, maybe reboot your modem OR you could call the ISP OR you could put the MAC address of your Netgear onto your ASA. I did that with my FiOS Service... works fine. HTH
Well the good news is that I got it fixed.
SOLUTION:
1) need ASA IOS 7.2.(2).22 or higher
2) DO NOT USE 'Cisco-interfaxce_name-' as the client-id
3) perform the command:
Interface vlanX
        dhcp client route distance 1
        ip address  dhcp setroute
      dhcp-client client-id interface outside
with vlanX being the correct vlan for your outside interface.
I actually had to do it twice before it would work right.  My current IOS is 8.0(4)
NOTE: running the command "dhcp-client client-id interface outside" is not enough by itself
