ISP LAN to WAN connectivity
I am making a basic topology and got stuck in the routing and need some help,
ISP(Internet) = Cisco RTR 2911 = Cisco 3650 SW  = System
I am getting IP on my system and am able to ping 192.168.10.2 that is Router's LAN interface but not able to browse, kindly let me know here I am wrong.
Below config for your reference
RTR config:
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool Treasury_ETI
network 192.168.10.0 255.255.255.0
default-router 192.168.10.2
dns-server 192.168.10.2
interface GigabitEthernet0/0
description *** LAN***
ip address 192.168.10.2 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description *** WAN - CONNECTED-TO-ISP-ONT***
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
ip nat inside source list NAT_LIST interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.100.1 (ISP End ISP)
ip access-list standard NAT_LIST
permit 192.168.10.0 0.0.0.255
Switch config:
interface GigabitEthernet2/0/1
description ADSL-TESTING-PORT
switchport access vlan 10
switchport mode access
interface GigabitEthernet2/0/48
description UPLINK-CONNECTED-TO-RTR
interface Vlan10
ip address 192.168.10.5 255.255.255.0
Giuseppe Larosa
Hello @asfandyar779514494 ,
your WAN interface is g0/1 not gi0/0 so do the following:
conf t
no ip nat inside source list NAT_LIST interface GigabitEthernet0/0 overload
ip nat inside source list NAT_LIST interface GigabitEthernet0/1 overload
end
wr mem
This should fix your issues
Hope to help
Giuseppe
thank you for your answer it had helped me
Hi Giuseppe,
Thanks man this solved my problem.
Now I am trying to do with 2 vlans (10 & 20) and made RTR LAN interface as Sub interface, I am able to get IP & ping gateway for vlan 10 but not able to browse internet.
What could be the issue, below config for your review,
RTR:
ip dhcp excluded-address 192.168.20.1 192.168.20.10
dns-server x.x.x.x
ip dhcp pool Treasury_DU
network 192.168.20.0 255.255.255.0
default-router 192.168.20.2
dns-server x.x.x.x
interface Embedded-Service-Engine0/0
no ip address
shutdown
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.2 255.255.255.0
--More--   description *** WAN - CONNECTED-TO-ONT***
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
!ip access-list standard NAT_LIST
permit 192.168.20.0 0.0.0.255
SW :
interface GigabitEthernet2/0/47
switchport trunk allowed vlan 10,20
switchport mode trunk
interface Vlan1
no ip address
interface Vlan10
under each router gi0/0 subif you need to add
ip nat inside
as NAT is triggered when going from a nat inside to a nat outside interface.
Hope to help
Giuseppe
