ISP latency
Jonathancert_2
Level 4
Level 4
As a network administrator, what is a good tool to measure ISP performance?  Users have been complaining about the latency at the browser level and from normal FTP services.  Sometimes Internet sites will time out while loading.  Some days things appear to be working fine.  Not noticing any congestion on my external WAN interfaces (see below)  but there is definitely a problem.  Before I contact our ISP, I want to conduct my own trend analysis.
WAN-RedRtr#sho int g3/1/0
GigabitEthernet3/1/0 is up, line protocol is up
  Hardware is GigEther SPA, address is c47d.4f6b.7240 (bia c47d.4f6b.7240)
  Description: Connection to DSW1 GI8/1
  Internet address is 172.147.162.122/31
  MTU 9216 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is auto, media type is SX
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:02, output 00:00:07, output hang never
  Last clearing of "show interface" counters 8w0d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1064000 bits/sec, 639 packets/sec
  5 minute output rate 3166000 bits/sec, 837 packets/sec
     2224704181 packets input, 437429288816 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 717583 multicast, 0 pause input
     2995898035 packets output, 1415667770032 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
WAN-RedRtr#sho int tunnel 10001
Tunnel10001 is up, line protocol is up
  Hardware is Tunnel
  Description: Interface to NE-REG-R7606-1 Tu#1
Internet address is 172.147.166.17/31
  MTU 17868 bytes, BW 622000 Kbit, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 10.147.166.17, destination 10.147.166.16
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 9192 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/202/202 (size/max/drops/flushes); Total output drops: 5
  Output queue: 0/0 (size/max)
  5 minute input rate 3282000 bits/sec, 733 packets/sec
  5 minute output rate 884000 bits/sec, 635 packets/sec
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 25527318 pkt, 2627237764 bytes
     3781236180 packets input, 2029774550585 bytes, 0 no buffer
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     2177744442 packets output, 422808095135 bytes, 0 underruns
Jonathan,
7 Replies 7
John Peek
Level 2
Level 2
I have the same issue with my ISP. They are having a really hard time understanding what I am asking them.
We used to use 2 T1s from sprint for our internet services. Everything worked fine. We then switched to TWTelecom for a 25Mbit fiber connection and I am having the exact same issues you are describing. We have to introduce a delay of up to 30 seconds on our FTP sessions for them to actually connect. We also noticed a higher delay in web traffic. Although, when you ping out, ping times are low and don't vary much.
I am working with my provider, but we can't really take down the internet connection for testing during business hours.
So, this most likely is an ISP problem but of course the non IT management that have fast internet at their house can't believe it could be the ISP fault.  Routing table and latency is looking good on the LAN.  Even with 6 hops, on a 21ms delay to reach the ISP.  Will keep looking for suggestions to back my theory.  Thanks.
21ms seems a little high to reach your isp. If you have another site with a slower connection, you can show management the difference between the two sites.
Here something else that you can do. http://www.cisco.com/en/US/docs/ios/ipsla/configuration/guide/sla_ftp.pdf
IP SLA's are your friend. I use them quite regularly. For instance, I have a sla set up to track jitter between my sites. I will be able to prove to my carrier that the jitter is higher than it should be.
I also use SLA's to detect when a link is starting to have issues by constantly pinging IP addresses within my network. If so many fail it will automatically failover to my backup link and then fail back when the line clears.
Hope this helps.
I have not utilized SLA features before.  Completed the configuration and trying to understand how the ouput can be baselined to aid in my troubleshooting.
You can download a free IP SLA tracker from Solarwinds.
http://www.solarwinds.com/products/freetools/ip_sla_monitor/
There are probably other free sla monitors out there, but I have found that solarwinds usually produces a superior product.
What you can do is perform two installs on seperate machines. One at a remote branch and the other at where you are having problems.
gerald.suiza
Level 4
Level 4
what i would do is trace to a public IP like 4.2.2.2 for example and see where the latency shoots up. i would also try and ping my public IP or the points where you see a surge in latency using a public gateways(you can source from various points all over the world). you can use the link below. this is to see if your ISP is having problems on their uplinks and peering points.
http://lg.level3.net/ping/ping.cgi?site=gen1&target=172.147.162.122&size=64&count=10
Thanks for the site.  Give me some direction to go.  I'm getting 60ms replies from www.yahoo.com
