ISP PPPoE dialer connection is flapping with virtual interface
CSCO12798688
Dear all,
I am facing issue with PPPoE connection this connection was working from the past 2 month suddenly one day stopped working.
always getting log like bound or unbound dialer 1 interface with virtual interface 1 line protocol up/down
dialer interface no longer able to get any ip address through ipcp, expecting your help.
under the dialer interface, make sure you have configured:
dialer idle-timeout 0
dialer persistent
Which router and IOS are you using ? Can you post the config ?
Using 1900
below are the exact configuration
interface Dialer1
 ip address negotiated
 ip accounting output-packets
 ip nbar protocol-discovery
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 ip tcp adjust-mss 1414
 dialer pool 1
 ppp pap sent-username ***** password *******
 no cdp enable
end
interface GigabitEthernet0/0
 description Outside interface
 no ip address
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
end
try and make the additions below to the configuration of your dialer interface:
interface Dialer1
ip mtu 1400
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1360
dialer pool 1
dialer persistent
no cdp enable
That said, the problem might be at a lower level, the physical one possibly. Can you change the cabling ?
Hello
Can you check for the correct authentication?
debug ppp negotiation
debug ppp authentication
Also debug the ppoe sessions
debug ppoe events
show ppoe session
Chap
int dialer1
mtu 1492
ip tcp adjust-mms 1452
ppp chap hostname xxxx
ppp chap password xxxxxx
IP route 0.0.0.0 0.0.0.0 dialer1
res
paul
Kind Regards
Paul
