ISP works on MS Windows broadband connection but fails on ISR 4451
varunoberoi
I am adding a third ISP connection to my ISR 4451. The pap username and password work when setup a new broadband connection on my windows 10 pro system and straight plug in the ISP wire.
But when I try to setup a Dialer on the Cisco router, the same username and password show an error "Login Incorrect" in the "debug ppp negotiation" output.
I have also tried chap, but no luck.
The configuration for the dialer is:
!WAN 3
config t
interface GigabitEthernet 0/0/3
no shutdown
pppoe enable group global
pppoe-client dial-pool-number 3
exit
interface dialer 3
no shutdown
no cdp enable
ip nat outside
ip address negotiated
ip mtu 1492
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 3
dialer-group 3
ppp authentication pap callin
ppp ipcp dns request
ppp ipcp route default
ppp pap sent-username orion password 818181xxxx
exit
exit
debug ppp negotiation output:
OrionRouter#debug ppp negotiation
PPP protocol negotiation debugging is on
OrionRouter#
*Feb 24 13:05:36.921: %DIALER-6-BIND: Interface Vi4 bound to profile Di3
*Feb 24 13:05:36.922: %LINK-3-UPDOWN: Interface Virtual-Access4, changed state to up
*Feb 24 13:05:36.922: Vi4 PPP: Sending cstate UP notification
*Feb 24 13:05:36.922: Vi4 PPP: Processing CstateUp message
*Feb 24 13:05:36.923: PPP: Alloc Context [7F58283277C8]
*Feb 24 13:05:36.923: ppp17 PPP: Phase is ESTABLISHING
*Feb 24 13:05:36.923: Vi4 PPP: Using dialer call direction
*Feb 24 13:05:36.923: Vi4 PPP: Treating connection as a callout
*Feb 24 13:05:36.923: Vi4 PPP: Session handle[C8000011] Session id[17]
*Feb 24 13:05:36.923: Vi4 LCP: Event[OPEN] State[Initial to Starting]
*Feb 24 13:05:36.923: Vi4 PPP: No remote authentication for call-out
*Feb 24 13:05:36.923: Vi4 LCP: O CONFREQ [Starting] id 1 len 10
*Feb 24 13:05:36.923: Vi4 LCP:    MagicNumber 0xED92E183 (0x0506ED92E183)
*Feb 24 13:05:36.923: Vi4 LCP: Event[UP] State[Starting to REQsent]
*Feb 24 13:05:36.924: Vi4 LCP: I CONFREQ [REQsent] id 1 len 22
*Feb 24 13:05:36.924: Vi4 LCP:    AuthProto PAP (0x0304C023)
*Feb 24 13:05:36.924: Vi4 LCP:    MRU 1492 (0x010405D4)
*Feb 24 13:05:36.924: Vi4 LCP:    MagicNumber 0x06D1197E (0x050606D1197E)
*Feb 24 13:05:36.924: Vi4 LCP:    MRRU 1600 (0x11040640)
*Feb 24 13:05:36.924: Vi4 LCP: O CONFREJ [REQsent] id 1 len 8
*Feb 24 13:05:36.924: Vi4 LCP: Event[Receive ConfReq-] State[REQsent to REQsent]
*Feb 24 13:05:36.924: Vi4 LCP: I CONFACK [REQsent] id 1 len 10
*Feb 24 13:05:36.924: Vi4 LCP:    MagicNumber 0xED92E183 (0x0506ED92E183)
*Feb 24 13:05:36.924: Vi4 LCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
*Feb 24 13:05:36.926: Vi4 LCP: I CONFREQ [ACKrcvd] id 2 len 18
*Feb 24 13:05:36.926: Vi4 LCP:    AuthProto PAP (0x0304C023)
*Feb 24 13:05:36.926: Vi4 LCP:    MRU 1492 (0x010405D4)
*Feb 24 13:05:36.926: Vi4 LCP:    MagicNumber 0x06D1197E (0x050606D1197E)
*Feb 24 13:05:36.926: Vi4 LCP: O CONFNAK [ACKrcvd] id 2 len 8
*Feb 24 13:05:36.926: Vi4 LCP:    MRU 1500 (0x010405DC)
*Feb 24 13:05:36.926: Vi4 LCP: Event[Receive ConfReq-] State[ACKrcvd to ACKrcvd]
*Feb 24 13:05:36.927: Vi4 LCP: I CONFREQ [ACKrcvd] id 3 len 14
*Feb 24 13:05:36.927: Vi4 LCP:    AuthProto PAP (0x0304C023)
*Feb 24 13:05:36.927: Vi4 LCP:    MagicNumber 0x06D1197E (0x050606D1197E)
*Feb 24 13:05:36.927: Vi4 LCP: O CONFACK [ACKrcvd] id 3 len 14
*Feb 24 13:05:36.927: Vi4 LCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
*Feb 24 13:05:36.958: Vi4 PPP: Phase is AUTHENTICATING, by the peer
*Feb 24 13:05:36.958: Vi4 PAP: Using hostname from interface PAP
*Feb 24 13:05:36.958: Vi4 PAP: Using password from interface PAP
*Feb 24 13:05:36.958: Vi4 PAP: O AUTH-REQ id 1 len 20 from "orion"
*Feb 24 13:05:36.958: Vi4 LCP: State is Open
*Feb 24 13:05:37.303: Vi2 PPP: Outbound cdp packet dropped, NCP not negotiated
*Feb 24 13:05:38.179: Vi4 PAP: I AUTH-NAK id 0 len 20 msg is "Login incorrect"
*Feb 24 13:05:38.179: Vi4 PPP DISC: We failed authentication
*Feb 24 13:05:38.179: PPP: NET STOP send to AAA.
*Feb 24 13:05:38.179: Vi4 LCP: I TERMREQ [Open] id 4 len 36
*Feb 24 13:05:38.179: Vi4 LCP: (0x75736572206F72696F6E206175746865)
*Feb 24 13:05:38.179: Vi4 LCP: (0x6E7469636174696F6E206661696C6564)
*Feb 24 13:05:38.179: Vi4 PPP: Phase is TERMINATING
*Feb 24 13:05:38.179: Vi4 LCP: O TERMACK [Open] id 4 len 4
*Feb 24 13:05:38.179: Vi4 LCP: Event[Receive TermReq] State[Open to Stopping]
*Feb 24 13:05:38.182: %DIALER-6-UNBIND: Interface Vi4 unbound from profile Di3
*Feb 24 13:05:38.183: Vi4 PPP: Block vaccess from being freed [0x10]
*Feb 24 13:05:38.183: Vi4 LCP: Event[DOWN] State[Stopping to Starting]
*Feb 24 13:05:38.183: Vi4 PPP: Unlocked by [0x10] Still Locked by [0x0]
*Feb 24 13:05:38.183: Vi4 PPP: Free previously blocked vaccess
*Feb 24 13:05:38.183: Vi4 PPP: Phase is DOWN
*Feb 24 13:05:38.183: %LINK-3-UPDOWN: Interface Virtual-Access4, changed state to down
*Feb 24 13:06:00.225: %DIALER-6-BIND: Interface Vi4 bound to profile Di3
*Feb 24 13:06:00.226: %LINK-3-UPDOWN: Interface Virtual-Access4, changed state to up
*Feb 24 13:06:00.226: Vi4 PPP: Sending cstate UP notification
*Feb 24 13:06:00.226: Vi4 PPP: Processing CstateUp message
*Feb 24 13:06:00.226: PPP: Alloc Context [7F58283277C8]
*Feb 24 13:06:00.226: ppp18 PPP: Phase is ESTABLISHING
*Feb 24 13:06:00.226: Vi4 PPP: Using dialer call direction
*Feb 24 13:06:00.226: Vi4 PPP: Treating connection as a callout
*Feb 24 13:06:00.226: Vi4 PPP: Session handle[7B000012] Session id[18]
*Feb 24 13:06:00.226: Vi4 LCP: Event[OPEN] State[Initial to Starting]
*Feb 24 13:06:00.226: Vi4 PPP: No remote authentication for call-out
*Feb 24 13:06:00.226: Vi4 LCP: O CONFREQ [Starting] id 1 len 10
*Feb 24 13:06:00.226: Vi4 LCP:    MagicNumber 0xED933C99 (0x0506ED933C99)
*Feb 24 13:06:00.226: Vi4 LCP: Event[UP] State[Starting to REQsent]
*Feb 24 13:06:00.228: Vi4 LCP: I CONFREQ [REQsent] id 1 len 22
*Feb 24 13:06:00.228: Vi4 LCP:    AuthProto PAP (0x0304C023)
*Feb 24 13:06:00.228: Vi4 LCP:    MRU 1492 (0x010405D4)
*Feb 24 13:06:00.228: Vi4 LCP:    MagicNumber 0x08F1D46D (0x050608F1D46D)
*Feb 24 13:06:00.228: Vi4 LCP:    MRRU 1600 (0x11040640)
*Feb 24 13:06:00.228: Vi4 LCP: O CONFREJ [REQsent] id 1 len 8
*Feb 24 13:06:00.228: Vi4 LCP: Event[Receive ConfReq-] State[REQsent to REQsent]
*Feb 24 13:06:00.228: Vi4 LCP: I CONFACK [REQsent] id 1 len 10
*Feb 24 13:06:00.228: Vi4 LCP:    MagicNumber 0xED933C99 (0x0506ED933C99)
*Feb 24 13:06:00.228: Vi4 LCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
*Feb 24 13:06:00.228: Vi4 LCP: I CONFREQ [ACKrcvd] id 2 len 18
*Feb 24 13:06:00.228: Vi4 LCP: O CONFNAK [ACKrcvd] id 2 len 8
*Feb 24 13:06:00.228: Vi4 LCP:    MRU 1500 (0x010405DC)
*Feb 24 13:06:00.229: Vi4 LCP: Event[Receive ConfReq-] State[ACKrcvd to ACKrcvd]
*Feb 24 13:06:00.229: Vi4 LCP: I CONFREQ [ACKrcvd] id 3 len 14
*Feb 24 13:06:00.229: Vi4 LCP:    AuthProto PAP (0x0304C023)
*Feb 24 13:06:00.229: Vi4 LCP:    MagicNumber 0x08F1D46D (0x050608F1D46D)
*Feb 24 13:06:00.230: Vi4 LCP: O CONFACK [ACKrcvd] id 3 len 14
*Feb 24 13:06:00.230: Vi4 LCP:    AuthProto PAP (0x0304C023)
*Feb 24 13:06:00.230: Vi4 LCP:    MagicNumber 0x08F1D46D (0x050608F1D46D)
*Feb 24 13:06:00.230: Vi4 LCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
*Feb 24 13:06:00.254: Vi4 PPP: Phase is AUTHENTICATING, by the peer
*Feb 24 13:06:00.254: Vi4 PAP: Using hostname from interface PAP
*Feb 24 13:06:00.254: Vi4 PAP: Using password from interface PAP
*Feb 24 13:06:00.254: Vi4 PAP: O AUTH-REQ id 1 len 20 from "orion"
*Feb 24 13:06:00.254: Vi4 LCP: State is Open
*Feb 24 13:06:01.467: Vi4 PAP: I AUTH-NAK id 0 len 20 msg is "Login incorrect"
*Feb 24 13:06:01.467: Vi4 PPP DISC: We failed authentication
*Feb 24 13:06:01.467: PPP: NET STOP send to AAA.
*Feb 24 13:06:01.467: Vi4 LCP: I TERMREQ [Open] id 4 len 36
*Feb 24 13:06:01.467: Vi4 LCP: (0x75736572206F72696F6E206175746865)
*Feb 24 13:06:01.467: Vi4 LCP: (0x6E7469636174696F6E206661696C6564)
*Feb 24 13:06:01.467: Vi4 PPP: Phase is TERMINATING
*Feb 24 13:06:01.467: Vi4 LCP: O TERMACK [Open] id 4 len 4
*Feb 24 13:06:01.467: Vi4 LCP: Event[Receive TermReq] State[Open to Stopping]
*Feb 24 13:06:01.469: %DIALER-6-UNBIND: Interface Vi4 unbound from profile Di3
*Feb 24 13:06:01.470: Vi4 PPP: Block vaccess from being freed [0x10]
*Feb 24 13:06:01.470: Vi4 LCP: Event[DOWN] State[Stopping to Starting]
*Feb 24 13:06:01.470: Vi4 PPP: Unlocked by [0x10] Still Locked by [0x0]
*Feb 24 13:06:01.470: Vi4 PPP: Free previously blocked vaccess
*Feb 24 13:06:01.470: Vi4 PPP: Phase is DOWN
*Feb 24 13:06:01.470: %LINK-3-UPDOWN: Interface Virtual-Access4, changed state to down
*Feb 24 13:06:01.470: Vi4 PPP: Sending cstate DOWN notification
*Feb 24 13:06:01.470: Vi4 PPP: Processing CstateDown message
*Feb 24 13:06:07.955: Vi3 PPP: Outbound cdp packet dropped, NCP not negotiated
*Feb 24 13:06:23.528: %DIALER-6-BIND: Interface Vi4 bound to profile Di3
*Feb 24 13:06:23.529: %LINK-3-UPDOWN: Interface Virtual-Access4, changed state to up
*Feb 24 13:06:23.529: Vi4 PPP: Sending cstate UP notification
6 Replies 6
I don't know if PAP works...can you try CHAP ?
interface dialer 3
no shutdown
no cdp enable
ip nat outside
ip mtu 1492
encapsulation ppp
dialer pool 3
dialer-group 3
ppp authentication chap callin
ppp chap hostname user_id@domain
ppp chap password 818181xxxx
My problem is, the username given by the ISP is simply "orion". There is no domain provided. I have asked him for this but he denies that one exists.
I tried chap with just orion and the password given, that does not work.
Should I insist on a domain?
I somewhere recall that you need to name the router the same as the username. Try and configure:
Router#conf t
Router(config)#hostname orion
Then use the PAP config you had before:
interface dialer 3
no shutdown
no cdp enable
ip nat outside
ip mtu 1492
encapsulation ppp
dialer pool 3
dialer-group 3
Nope, that did not help.
looking at the debug output:
The login you use (username and/or password) seem to be incorrect...it could be that the ISP needs to clear something on their side first (since you connected from a Windows machine). I would check with them again.
what's going on between Feb 24 13:05:36.958 and 13:05:38.179 ??   try enabling the following debugs to see if these fill in that gap in the debug message exchange.
debug ppp authentication
debug ppp error
debug aaa authentication
