02-10-2023 08:02 AM
Im new, learning and studying for CCNA, Have a home lab.
I have a ISR 1921, PID CISCO1921/K9 V05 That appears to have two exapnsion hwic or ehwic module slots. I'm assuming i can use an HWIC but not sure about the EHWIC. I want to add interfaces so that i can connect this router to another 1921 and have interfaces available to connect switches.
Can the ports on the HWIC or EHWIC be used for connecting routers together?
Solved! Go to Solution.
02-10-2023 01:38 PM
Sure this is WIC, so you can connect to any device that has Ethernet support.
=====️ Preenayamo Vasudevam ️=====
02-10-2023 09:16 AM
EHWIC offers high data rates, if this is for testing, you have install HWIC and do testings.
check module features section :
02-10-2023 10:01 AM
Can these cards be used to connect multiple switches to the ISR 1921?
02-10-2023 01:38 PM
02-10-2023
03:22 PM
- last edited on
02-12-2023
09:55 PM
by
Translator
This is what you really want to possibly start with:
09 Jan 2019 - √ √ 4-port clear-channel T1/E1 HWIC Data Sheet HWIC-4T √ √ 4-port serial HWIC Data Sheet Q&A HWIC-1DSU-T1 √ √ √ 1-Port T1/Fractional T1 DSU/CSU High-Speed ... Interface Card (HWIC) Data Sheet HWIC-2CE1T1-PRI √ √ 2-port Channelized E1/T1/ISDN PRI HWIC Data Sheet Note: Not supported on the Cisco 2901 HWIC-1CE1T1-PRI ... HWIC, EIA-232 Data Sheet Q&A HWIC-4A/S √ √ √ 4-port Async/Sync Serial HWIC Data Sheet Q&A HWIC-
