ISR 4000 IP Base
vivarock12
Hello support community.
Can someone confirm for if the new ISR 4000 series router with IP Base license is capable of running GRE/IPSEC (GRE over IPSEC) and GRE/IPSEC on VRF (GRE over IPSEC on VRF)?
From what i have found i dont know if i a need a license or not i fpund the next tools but is not clear to me either:
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
Version
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
The Image is from the Next Link:
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-732542.html
Gerardo Andree Mejía
Hulk8647
whats the model of the ISR?
Thanks for the Reply the model os the ISR is 4351.
But i also have a 4431 and 2 4221 so if you have the info for all of this if router can you help me with this ones too thanks by the way.
Looks like you should be OK with the base. See the pic on how to use the cisco feature navigator.
Ben Samayoa
Hola Gerardo,
Please check the following link, this tool will help to answer all your questions:
http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
Hopefully you'll sort this out.
regards,
Ben
