ISR 4321
Ivan Jovovic
Visitor
I have ISR 4321 router on test, but I have problem with LTE (4G network) configuration. I follow configuration guid but I haven't connection to mobile network. Do you have some experience with this device and this configuration LTE. If you have some document or configuration pls share.
5 Replies 5
Hitesh Vinzoda
Level 10
Level 10
Hi there,
please look at the below documentation and share your existing configuration and provider name/Region.
http://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/NIM/software/configuration/guide/4GLTENIM_SW.html#pgfId-1396817
Hitesh
Thank you for support. I solved problem with 4G, problem was with sim card APN, but I have new problem with tracking.
I want to configure two route primary and backup. I will enclose configuration in attach. If you have some idea pls shere with me.
Ivan
Ivan,
Your configuration looks fine to me. Are there any issues that you are facing ?
Hitesh
Hitesh,
config looks fine, but I haven't Internet access from dialer interface. On this interface I have public IP address, but I think trackin is problem, because always is active cellular. Dialer route has better metric then cellular but cellular is active.
Ivan
Hi Ivan,
Can you post show track and show ip sla statistics and also try removing track just to check if normal internet access works through dialer.
Hitesh
