ISR 4331 ip inspect command not available despite securityk9 license being present
jonder
I am testing out a new 4331 (15.4(3)S2) with securityk9 licensing enabled.  However, ip inspect is not recognized as a valid command.  Has this been moved to another license?  Or is there a particular service I need to enable first?  I'm not currently finding much via here nor google.
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
appxk9                   yes          yes         no             no       yes
uck9                     yes          yes         no             no       yes
securityk9               yes          yes         no             yes      yes
ipbasek9                 no           no          no             yes      no
cme-srst                 yes          yes         no             no       yes
hseck9                   yes          no          no             no       no
throughput               yes          yes         no             no       yes
internal_service         yes          no          no             no       no
Joe
felix.kessels
Hi do have this Problem too.
I tried migrating a 2811 VSEC to 4331 VSEC and failed because auf IP inspect not present.
I then decided to go with ZBF but that Failed to because this router is a h323 gateway and after configuring ZBF i got working connections, but unidirektional voice streams, Phone -> Router -> ISDN is working,  ISDN -> Router -> phone is not working.. I tried 3 -4 different ways, when I remove ZBF Voice is working as expected but I do not have that Firewall Feature for local Internet Breakout
