ws-c4948 Layer2 mode??
Soon Kwan Kwon
hi all
It is just very simple question
In order to use 4948 switch layer 2 mode, what can I do configure special?
I think No configuring something I should do?
and I think just inserting UTP cable to thr switch => L2 mode ,, is it right?
Thank you all!
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You might need to configure the port as a switchport and not a routed port.  A 4948 should support either, but I don't know which is its default.
Thank you Joseph ^^
Nagendra Kumar Nainar
Joseph is right. I thnk the default mode is switchport. By default all the ports will be in vlan 1. So you can make it as L2 switch without any configuration.
HTH,
Nagendra
Ok Nagendra!
Thank you^^
