ISR 4331 network-clock synchronization automatic added on reboot
Jim Matuska
On a ISR 4331router every time I reboot it adds the
command to my configuration even though I put in the
no network-clock synchronization automatic
configuration and saved before reboot.  This is really annoying since I need to have this disabled in order to allow me to synchronize the router with the T1/PRI port from my voice carrier using the
network-clock input-source 1 controller T1 0/1/0 and clock source line primary
(under my controller T1 0/1/0) configuration.
Without clocking to the telco I get slip seconds incrementing on the T1 controller.
Is this some sort of bug?  I am running version isr4300-universalk9.17.06.01a.SPA.bin
I have ruled out my callmanager servers causing this configuration change by removing the
ccm-manager config
command from my configuration and rebooting and it still adds back the clock auto synchronization.
Any thoughts?
Jim Matuska
I really don't want to have to build a script for a workaround to a potential bug, but I did find a solution to keep my PRI's from getting slip seconds incrementing and using the
so my configuration doesn't change on reboot.  For reference both the old and new configurations below work for our PRI voice circuit and don't give any clocking errors on the PRI but the only problem with the old configuration is that it adds the
command on reboot.
Does anyone see any issues with the new configuration?
Old Config
controller t1 0/1/0
New Config
controller t1 0/1/0
no network-clock synchronization participate 0/1
no network-clock input-source 1 controller T1 0/1/0
M02@rt37
Hello @Jim Matuska
It's possible that the addition of the
command to your configuration after reboot is a bug in the ISR 4331 router software.
As I concerned, I've created an EEM script that runs automatically upon boot and removes the
command from the configuration. This script is triggered by a specific event, such as the completion of the boot process or the detection of the clock synchronization command in the configuration.
Best regards
Jim Matuska
command on reboot.
Old Config
controller t1 0/1/0
New Config
controller t1 0/1/0
