ISR 4431: Assign IP Address on interface
Alexandros86
i have a router 4431 and i am trying some old configuration that they gave me for this model.
I have a license securityk9 but except in the interfaces G0/0/0 - 0/0/3 i am not able to assign IP on the int G0/1/0 - 0/1/7 and there is not possible to use right now any SFP.
I enable ip routing and the "no switchport" on the interfaces is not possible.
Any other suggestion?
Thanks  a lot.
2 Accepted Solutions
If port not accept IP address
Make port l2 via switchport and assign specific vlan to it
Config vlan SVI
Stefan Mihajlov
Level 3
Level 3
@Alexandros86
It looks like interfaces G0/1/0 - G0/1/7 on the ISR 4431 are part of an internal switch module, which operates as Layer 2 by default, so you cannot directly assign an IP address to them. To work around this, you can create a VLAN interface (SVI) and assign an IP address to it. Use the following commands:
  1. Create a VLAN and assign an IP address:
    interface vlan <VLAN-ID> ip address <IP-ADDRESS> <SUBNET-MASK> no shutdown
  2. Assign the desired interfaces to the VLAN:
    interface range g0/1/0 - g0/1/7 switchport mode access switchport access vlan <VLAN-ID>
This will allow the VLAN to act as the routed interface for those Layer 2 ports. If you still need routed ports instead of switchports, confirm if a license upgrade or configuration change is required.
If this post was helpful, please click Helpful. If it resolved your query, select Mark as Solution from the dropdown menu in the top-right corner of this reply.
Config vlan SVI
thats was my idea but i still waiting for feedback witch vlans the use and i can take in this case. There is not possible to enable routing on the interface and assign an ip?
Stefan Mihajlov
Level 3
Level 3
@Alexandros86
i know this way with vlan, i was not sure if there is another workaround and to activate the l3 on the module.
if not then i will use VLAN.
