isr debug platform packet
hi,
is it possible to get some more detail about tcp packet during debug platform traces? Like length of packet or even sequence numbers?
br
8 Replies 8
 It depends on the device. You can generate a pcap file and run in Wireshark for easy viewing.
i do not need pcap, I need packet lengths or sequence numbers  in "show platform packet all" output
debug ip tcp packet <- give you SYN ACK
debug ip tcp ha <- give you length
give more detail about TCP traffic.
monitor capture on interface of receiving router (isr) shows OOO packets and monitor capture on interface of sending router shows no OOO packets. So I want to do platform debug packet trace and see if it will show OOO packets. But I need lengths or sequences to be shown so I could identify packets and verify order
Can you provide how it is configured, sample example output for us to understand the issue here.
BB
Debug plat cond ipv4 access-list ACL both
Debug plat packet packet 1024 fia-trace
and in trace results I do not see anything I could use to pinpoint packets, beside src/dst ports
on this link
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/xe-16-12/asr1000-software-config-guide-16-12/pkt-trace-asr.html
there are some sample outputs where tcp sequences are visible, but I cannot get this to work
this is sample output from documentation
Router#show platform packet-trace packet  12
Packet: 12          CBUG ID: 767
Summary
  Input     : GigabitEthernet3
  Output    : internal0/0/rp:0
  State     : PUNT 11  (For-us data)
  Timestamp
    Start   : 16120990774814 ns (01/20/2020 12:38:02.816435 UTC)
    Stop    : 16120990801840 ns (01/20/2020 12:38:02.816462 UTC)
Path Trace
  Feature: IPV4(Input)
    Output      : <unknown>
    Source      : 12.1.1.1
    Destination : 12.1.1.2
    Protocol    : 6 (TCP)
      SrcPort   : 46593
      DstPort   : 23
IOSd Path Flow: Packet: 12    CBUG ID: 767
  Feature: INFRA
    Pkt Direction: IN
    Packet Rcvd From DATAPLANE
  Feature: IP
    Pkt Direction: IN
    Packet Enqueued in IP layer
    Source      : 12.1.1.1
    Interface   : GigabitEthernet3
  Feature: IP
    Pkt Direction: IN
    FORWARDEDTo transport layer
    Source        : 12.1.1.1
  Feature: TCP
    Pkt Direction: IN
    tcp0: I NoTCB 12.1.1.1:46593 12.1.1.2:23 seq 1925377975 OPTS 4 SYN  WIN 4128
there is some commend need before the show display the TCP packet
please see below slide.
