ISR E1 modules/interfaces
RanilG
Level 3
Level 3
What are the E1 network modules/interfaces supported by c1841?
Is there a link to for quick reference in general?
Show version on a c1841 indicates that it has 1 Channelized E1/PRI port.
What could be the corresponding module?
Is it NM-1CE1U, NM-1CE1B or something else?
5 Replies 5
njorosam
Hi Give an email where i can mail u an good reference doc.
It's rsgamage1@gmail.com
Thanks in advance.
Richard Burts
Ranil
This link has much good information about the 1841:
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016a59b.html
and if you look in table 6 it lists the various modules (including E1s) that are supported on the 1841.
Rick
Rick
Hi Richard,
Thanks for the link.
Can you comment on my second query as well please? Is there a way to identify the corresponding module with "sh version" or otherwise?
OK I'll provide the answer myself.
show diag says that it has a VWIC-1MFT-E1 (Multi-Flex Trunk WAN) module.
According to table 6 this module has data only support on c1841.
