ISR4321 VDSL couldn't detect when configure mode auto
Looi Siew Key
We have 1 router ISR 4321 which add ATM module into it.
Deploy with "controller vdsl 0/2/0" as virtual DSL interface referring to dialer 1 (to ISP).
When configure "operating mode auto" inside "controller vdsl 0/2/0" interface, it doesn't able to detect which ISP protocol is using.
Whenever configured using manual way can work, example like "operating mode adsl2+"
Only 1 of the branch causing this issue and temporary running using manual protocol configured. Other branch using auto mode works fine.
Configuration syntax in ISR 4321;
     operating mode auto (this command will not appear after configured)
Firmware:
IOS XE v03.16.05.S - extended support release
7 Replies 7
if only one site experiences that problem, the issue could be the DSLAM of your ISP. Compare the output of 'show controller vdsl 0/2/0' of the site with the problem, and one site where operating mode auto is working.
Or post the output here...
Hi Georg,
working on manual ADSL2+;
kmartr01#sh controllers vdsl 0/2/0
Controller VDSL 0/2/0 is UP
Daemon Status:          UP
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'BDCM'
Chip Vendor Specific:   0x0000                   0xA4F8
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   'BDCM'
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0xB500
Serial Number Near:     <S/N> 4321/K9 15.5(3)S5
Serial Number Far:
Modem Version Near:     15.5(3)S5
Modem Version Far:      0xa4f8
Modem Status:           TC Sync (Showtime!)
DSL Config Mode:        ADSL2+
Trained Mode:           G.992.5 (ADSL2+) Annex M
TC Mode:                ATM
Selftest Result:        0x00
DELT configuration:     disabled
DELT state:             not running
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Modem FW  Version:      4.14L.04
Modem PHY Version:      A2pv6F039p1.d26d
Line 0:
Trellis:                 ON                      ON
SRA:                     disabled                disabled
SRA count:               0                       0
Bit swap:                enabled                 enabled
Bit swap count:          300                     0
Line Attenuation:         6.5 dB                  4.9 dB
Signal Attenuation:       7.0 dB                  4.6 dB
Noise Margin:            12.1 dB                28.7 dB
Attainable Rate:        26088 kbits/s            1312 kbits/s
Actual Power:           12.1 dBm                12.4 dBm
Total FECC:             931292                   23
Total ES:               63                       19
Total SES:              70                       0
Total LOSS:             5                        0
Total UAS:              3929                     3859
Total LPRS:             0                        0
Total LOFS:             38                       0
Total LOLS:             0                        0
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             NA           25333            NA               509
SRA Previous Speed:       NA               0            NA                 0
Previous Speed:           NA           25302            NA               509
Total Cells:              NA      2328353797            NA         824873869
User Cells:               NA          861188            NA            839324
Reed-Solomon EC:          NA            8181            NA                 0
CRC Errors:               NA            3090            NA                42
Header Errors:            NA               0            NA                 0
Interleave (ms):          NA            0.30            NA             14.05
Actual INP:               NA            0.01            NA              5.91
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
Below are working on AUTO;
Daemon Status:          UP
Chip Vendor Specific:   0x0000                   0x939E
Serial Number Far:
Modem Version Far:      0x939e
DSL Config Mode:        AUTO
Trained Mode:           G.992.5 (ADSL2+) Annex A
TC Mode:                ATM
Short inits:            0
Line 0:
Trellis:                 ON                      OFF
SRA count:               0                       0
Bit swap count:          0                       0
Line Attenuation:        12.5 dB                  5.6 dB
Signal Attenuation:      11.6 dB                  5.1 dB
Noise Margin:            38.2 dB                27.5 dB
Attainable Rate:        22972 kbits/s            1026 kbits/s
Actual Power:            5.8 dBm                12.4 dBm
Total FECC:             0                        0
Total ES:               11                       0
Total SES:              11                       0
Total LOSS:             1                        0
Total UAS:              223                      212
Total LPRS:             0                        0
Total LOFS:             9                        0
Total LOLS:             0                        0
Speed (kbps):             NA            2047            NA               509
Previous Speed:           NA            2047            NA               509
Total Cells:              NA      1951781946            NA        1555242021
User Cells:               NA         2104647            NA           1408640
Reed-Solomon EC:          NA               0            NA                 0
CRC Errors:               NA             484            NA                 0
Interleave (ms):          NA           15.00            NA             13.81
Actual INP:               NA           58.00            NA              1.84
Is any of the above output belongs to non-working site?
-Amit
Nope, attached above output with Working & Non-Working site.
ADSL2+ = manual mode configure (non-working)
AUTO = auto mode (working)
try and check with the ISP what DSLAM they use at both sites.
Hi Georg,
DSLAM is checked from ISP site? Can we detect it from router ATM interface itself?
Looi Siew Key
Anyone having similar issue which solved?
Please assists, thanks alot.
