ISR4351 Won't boot on new IOS version
louisKl1
I am working on an ISR4351. It is currently running version 15.5(3)S4b, and we want to update it to 17.3.4a so it can support smart licensing.
I have followed many community discussions and haven't found my problem.
#show version
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
System restarted at 19:41:48 MET Wed Dec 15 2021
System image file is "bootflash:/isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bi"
Last reload reason: Reload Command
#sh run | i boot
boot-start-marker
boot system flash bootflash:/isr4300-universalk9.17.03.04a.SPA.bin
boot-end-marker
#dir
Directory of bootflash:/
11 drwx 16384 Dec 31 2016 03:44:07 +01:00 lost+found
1343489 drwx 4096 Dec 15 2021 19:42:04 +01:00 .prst_sync
12 -rw- 486645440 Dec 31 2016 04:02:30 +01:00 isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
15 -rw- 702197190 Dec 15 2021 17:01:58 +01:00 isr4300-universalk9.17.03.04a.SPA.bin
#show bootvar
BOOT variable = bootflash:/isr4300-universalk9.17.03.04a.SPA.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
#sh platform
HQ692#sh platform
Chassis type: ISR4351/K9
Slot Type State Insert time (ago)
0 ISR4351/K9 ok 19:24:33
0/0 ISR4351-3x1GE ok 19:23:30
0/1 NIM-2BRI-NT/TE ok 19:23:30
0/2 NIM-2FXS ok 19:23:30
0/4 PVDM4-64 ok 19:23:30
1 ISR4351/K9 ok 19:24:33
2 ISR4351/K9 ok 19:24:33
R0 ISR4351/K9 ok, active 19:24:33
F0 ISR4351/K9 ok, active 19:24:33
P0 PWR-4450-AC ok 19:24:12
P2 ACS-4450-FANASSY ok 19:24:12
Slot CPLD Version Firmware Version
0 15030325 15.4(3r)S5
1 15030325 15.4(3r)S5
2 15030325 15.4(3r)S5
R0 15030325 15.4(3r)S5
F0 15030325 15.4(3r)S5
I have checked file hash to make sure and it matches the one given by Cisco :
verify /md5 (bootflash:isr4300-universalk9.17.03.04a.SPA.bin) = 48992d5bb985b071648921b1e7ad4c96
MD5 Checksum : 48992d5bb985b071648921b1e7ad4c96
Thank you for your help
louisKl1
In fact the rommon software installed was to old to boot the new IOS.
For anyone who would like to check their current version, show rom-monitor r0
Mark Elsen
 - Could you try to remove / in the boot-command : boot system flash bootflash:/isr4300-universalk9.17.03.04a.SPA.bin as in
 #sh run | i boot
boot-start-marker
boot system flash bootflash:isr4300-universalk9.17.03.04a.SPA.bin
boot-end-marker
 M.
louisKl1
johnlloyd_13
Level 9
Level 9
hi,
you should check the 17.x release notes first and upgrade to a compatible ROMMON package 16.12(2r) before the main IOS-XE:
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/release/xe-17-3/isr4k-rel-notes-xe-17-3.html
also remove the forward slash "/" in the boot system flash command.
#upgrade rom-monitor filename bootflash:<ROMMON.pkg> all
