issue connecting two router, with T1 controller and serial T1
ahmad82pkn
Level 3
Level 3
Hi, i want to connect two routers via private line, Provider has installed cable on my both facilities.
on one side of router RTRA, i have controller T1
sh version
Channelized T1/PRI ports
on second side RTRB i have serial T1 ports.
sh version
1 Serial interfaces
both have rj45 like connectors, can any one tell me what would be configuration of controllers on both side?
on RTRA side, i have this configuration
controller T1 0/0
framing sf
clock source internal
linecode ami
channel-group 0 timeslots 1-24 speed 64
what would be on RTRB side?
and what kind of cabl ei should use? provider said to use straight cables.
paolo bevilacqua
Straiht cable, but NOT ethernet. T1 cable, should in the box with cards.
paolo bevilacqua
ok, i am making that, lets see
Ahmad:
Just a footnote...the T1 pinouts are 1,2,4 and 5.
Victor
