issue with CCP
coreacorea
Community Member
   anyone experience this issue shown in the picture?  The display does not fit within the explorer window screenshot.png
Arsen Gharibyan
Level 3
Level 3
Hello
Change ur browsers compability settings and add 127.0.0.1 as a website
then run CCP as Admin, it should work fine
Arsen Gharibyan
Network Engineer
thank you for your response but adding the loop back did not resolve the issue the home screen aligns just fine
hi,
could you adjust your monitor screen to 1024 x 768?
adjusting the screen resolution did not work.  I tried everything from different versions of java and ccp.
