Issue with Interface speed and duplex settings on 2900 series router.
gkchakravarthy
we have connected gig interface ethernet on cisco 2900 series router to mpls link connected to our corporate network ,the issue here is our router interface speed and duplex settings are set to auto negotiation.The interface is negotiating speed and duplex at 10 and half where the provider side interface is hard coded to 100 and full duplex.when we tried to hard code the settings on our router to match the provider the interface never come up.please suggest
John Blakley
Try changing the cable. If they're hard coded at 100/F, you should be hard coded at 100/F. If not, you can see the autonegotiation process end with 100/H. So, if the interface doesn't come up with 100/F hard coded, see if replacing the cable can help.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John,
we did not tried by changing the cable ,but moved to different port and checked still it is negotiating 10/H will check by changing the cable.
Thanks.
patrick.preuss
Maybe the Provider Set 10/f ;)
Double Check it with them.
Marc
This was the reply from SP
Please be advised that the local carrier is hard coded for 100/ full with no auto negotiation. Please confirm your interface settings are set for 100/full as well. We will hold this case pending youre response.
GK.
