Issue with OSPF
zac32235
Hello, I am trying to configure OSPF so that all the end devices can ping each other. After configuring the routers, only PC0, 1 & 3 can ping each other. I tried to manually add R6 into R4 by the neighbor command but "Neighbor command only allowed on NBMA and P2MP networks" errors pops up. I got the same result when I tried to add R2 into R5.
R2---------------
R5--------------
R4---------------
R6----------------
10 Replies 10
M02@rt37
Hello @zac32235
R3 seems to be the only ospf adjencies with it loopback 7.7.7.7
Do R3 and R5 ping Gi0/1 R2 interface ?
Please share ospf process config of each routers. Thanks.
Best regards
Hi, R3 and R5 are not able to ping R2.
R1 no OSPF. Connected to R2 via static route
R2----
router ospf 54
network 183.25.4.176 0.0.0.7 area 0
network 183.25.4.184 0.0.0.7 area 0
R3----
router ospf 54
network 183.25.4.192 0.0.0.3 area 0
R4----
router ospf 54
network 183.25.4.64 0.0.0.63 area 1
network 183.25.4.0 0.0.0.63 area 2
R5----
router ospf 54
network 183.25.4.160 0.0.0.15 area 0
R6----
router ospf 54
network 183.25.4.196 0.0.0.3 area 1
@zac32235
Thanks. So debug why R3 and R5 are not able to ping R2 Gi0/1 interface. Check Switch config etc...
Best regards
I dont have PKT now in my phone' and M02@rt37 can help you alot in this task
I will give you hint what is your mistake
You config area 0 not between router' i.e. the area 0 is split which is need virtual link or you can re-arrange topolgy and make the center router use area 0 and sided router use other area
MHM
Hi I tried doing the virtual link but I got the error below while debugging
This is the topology I'm trying to achieve so I am unable to change the topology
Hello
You do not require a VL, the the ospf BB ( r2-3-5) is NOT discontingous as R4(ABR) also has connection to the BB via R3
Kind Regards
Paul
Can mention the area you use in each router'
Make circile for each area
MHM
this design
NOTE:- R2 R3 R5 need to be in same subnet if area0 since routers connect via SW
SW must use same VLAN to connect R2 R3 and R5
Hi, I managed to fix my issue. I went back to check my connections and found that the R2 connections got swapped. For R4 I had to add the area manually to the interface itself and it works. Thank you for your help!
Friend you are so welcome
Have a nice weekend
MHM
