Issue with TFTP upgrade
bender.mike
I'm experiencing a problem with performing TFTP upgrades through a site-to-site tunnel between a CVPN3015 and a 831 router.
I suspect that it's an issue with an ACL. Can anyone see anything that I'm missing?
TFTP server has IP 10.64.0.x. I can perform extended ping from inside interface, but standard ping times out.
Sample config:
interface Ethernet0
description $FW_INSIDE$$ETH-LAN$$INTF-INFO-Ethernet 10/100$
ip address 10.0.0.129 255.255.255.128
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1300
ip policy route-map clear-df
no cdp enable
interface Ethernet1
description $FW_OUTSIDE$$ETH-WAN$
ip address 65.65.65.65 255.255.255.248
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect DEFAULT100 out
ip route-cache flow
duplex auto
no cdp enable
crypto map USKK2K
ip classless
ip route 0.0.0.0 0.0.0.0 65.65.65.66
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
logging trap debugging
access-list 1 remark HTTP Access-class list
access-list 1 remark SDM_ACL Category=1
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 1 deny any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 192.168.0.1 0.0.0.7 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 remark Auto generated by SDM for NTP (123) 10.1.0.1
access-list 102 permit udp host 10.1.0.1 eq ntp host 65.65.65.65 eq ntp
access-list 102 permit udp host 10.1.0.2 eq domain any
access-list 102 permit udp host 10.1.0.3 eq domain any
access-list 102 permit ahp host 64.64.64.65 host 65.65.65.65
access-list 102 permit esp host 64.64.64.65 host 65.65.65.65
access-list 102 permit udp host 64.64.64.65 host 65.65.65.65 eq isakmp
access-list 102 permit udp host 64.64.64.65 host 65.65.65.65 eq non500-isakmp
access-list 102 permit icmp any host 65.65.65.65 echo-reply
access-list 102 permit icmp any host 65.65.65.65 time-exceeded
access-list 102 permit icmp any host 65.65.65.65 unreachable
access-list 102 remark IPSec Rule
access-list 102 permit ip 10.0.0.0 0.255.255.255 10.0.0.128 0.0.0.127
access-list 102 deny ip 10.0.0.128 0.0.0.127 any
access-list 102 deny ip 172.16.0.0 0.15.255.255 any
access-list 102 deny ip 192.168.0.0 0.0.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip host 0.0.0.0 any
access-list 102 deny ip any any log
access-list 103 permit ip 10.0.0.0 0.255.255.255 any
access-list 103 deny ip any any
access-list 104 remark DF-bit Clear list
access-list 104 permit ip 10.0.0.0 0.255.255.255 any
access-list 150 remark SDM_ACL Category=4
access-list 150 permit ip 10.0.0.128 0.0.0.127 10.0.0.0 0.255.255.255
access-list 150 permit icmp 10.0.0.128 0.0.0.127 10.0.0.0 0.255.255.255
access-list 150 deny ip any any
no cdp run
route-map clear-df permit 10
match ip address 104
set ip df 0
---------end config
Thanks for any help!
Mike
Richard Burts
Mike
I believe the basic issue is that by default the TFTP packets are sent using the source address of the outbound interface (in this case Ethernet 1). Since you did not include the crypto map in the posting we can not tell whether that traffic is included in the IPSec tunnel but I am guessing that it is not. The other part of the issue is that inteface Ethernet 1 has inbound access list 102. This access list permits some NTP, some DNS, IPSec and traffic from 10.0.0.0 to 10.0.0.128. But it has no permit for non-IPSec with destination address of 65.65.65.65 and I believe this includes tftp.
I believe there is an easy solution. If you include this in the config:
ip tftp source-interface ethernet 0
this will source the tftp from the ethernet 0 interface. I believe the return traffic will be permitted if it is sourced from ethernet 0.
Rick
Rick
Rick,
Thanks for the reply. That indeed resolved the problem. I figured the problem was that tftp was using Eth1 for the source address, which was why I suspected my ACLs. I also figured there had to be a way to specify TFTP to use a different source address.
Mike
Mike
Thanks for the update indicating that the problem is resolved. It helps make the forum more valuable when people read discussion of a problem and can see what the solution turned out to be.
I am glad that we were able to help solve your problem.
Rick
Rick
