PAT with NAT for inbound connections query
anup.patel
Router : 877W & 857
IOS : 12.3(8)YI2 & 12.3(8)YI3
I'm new to IOS, so I may be asking something that has been documented, however I cannot find it, so......
Can anyone confirm if its possible to perforn a NAT and PAT for inbound connections at the same time? If so, a pointer to the doc's or command would be helpful.
Basically I want to be able to RDP to multiple machines using a different port number, but not have to change the recieving systems default port number.
For example:
Global Address1:33101 --> Inside Address10:3389
Global Address1:33102 --> Inside Address20:3389
Global Address2:33101 --> Inside Address100:3389
Global Address2:33102 --> Inside Address200:3389
Thanks in advance.
Anup
tekha
Level 3
Level 3
Try this:
ip nat inside source static tcp Inside-Address.10 3389 Global-Address.1 33101 extendable
ip nat inside source static tcp Inside-Address.20 3389 Global-Address.1 33102 extendable
ip nat inside source static tcp Inside-Address.100 3389 Global-Address.2 33101 extendable
ip nat inside source static tcp Inside-Address.200 3389 Global-Address.1 33102 extendable
Hello Tekha,
Thank you very much for the fast response & commands. I had tried something similar, but I must have made mistakes, since IOS kept responding with a message stating that the port 3389 was already being used. I got no such message with your commands. I will verify functionality and advise accordingly.
Once again thanks.
Anup
