Issues with single MPLS backbone?
Farhan Jaffer
I am going to start a design of IP/MPLS backbone with three P routers & three PE routers. I wish to enable L3VPN, AToM & VPLS on a single backbone. What are the possible issues in this solution?
What are the recommended routers for this? budget is very limited & need to entertain only some dozen of customers.
Thanks in advance.
Steve Lyons
I would recommend providing your requirements to your Cisco account team and asking for their assistance. They can assist you with which hardware fits your requirements. You will want to make sure the code you choose supports the features you are interested in. The hardware should be selected based on feature support and capacities required, i.e.: bandwidth, cpu, etc.
Steve Lyons - Cisco
