It is possible when radius authentication fail, port shutdown ?
cwhlaw2009
I trying 802.1x mac based authentication by c3560 and freeradius, everything is ok and then i trying how to shutdown the port when fail 3 time.
I tried add authentication violation shutdown but not work, I tried add dot1x max-req 3 or max reauth-req 3 is still not work.
How can I shutdown the port when fail 3 time?
Francesco Molino
you can use authentication event fail retry command for retries.
And the command authentication violation shutdown command to shut a port in case of failure.
thanks
PS: Please don't forget to rate and mark as correct answer if this solved your issue
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
thanks
Francesco
