iWAN Configuration
abbasali5
I am trying to find a install and configure guide for Cisco 3900 ISR with iWAN Configuration.  Was not able to find any good document where it can explain the required Hardware and Software feature in order to enable iWAN on Cisco 3900 ISR router.  There are a few requirements such as where and how to enable Intelligent Path Control and Application Optimization on the same Router used for MPLS and Internet Circuit or enable iWAN on separate 3900 ISR router etc.
milan.kulik
Level 10
Level 10
what about Appendix A of this document?
http://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Feb2016/CVD-IWANDesignGuide-FEB16.pdf
BR,
Milan
Brandon Lynch
As Milan noted below, the CVD is the best resource for understanding the design and how to implement PfRv3. I recommend reading over that guide first to understand the underlying design principles and requirements first. If you have concerns about the configuration, there was also a CVD released in January of this year which provides more example configurations for both branch and hub sites -
http://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise-networks/intelligent-wan/cvd-iwanconfigurationfilesguide-jan15.pdf
You will need the 'datak9' license to enable PfRv3. Thanks.
Brandon
