*Jan 19 01:36:50.859: %BGP-4-BGP_LABELS_NOT_SUPPORTED: BGP neighbor 2001:DB8:100::171 does not support sending labels
Marc du
Hello
How can i solve the below error
thanks all
7 Replies 7
without having seen your configuration, check if the below applies:
Cisco IOS Release 15.0(1)S3a
The following behavior changes are introduced in Cisco IOS Release 15.0(1)S3a:
There is a new BGP error message.
Old Behavior: No error message is generated when BGP neighbors are configured with both an IPv6 address and MPLS send labels (via the neighbor send-label command or via a template). Sending MPLS labels to IPv6 peers is not supported.
New Behavior: An error message is generated when BGP neighbors are configured with both an IPv6 address and MPLS send labels. An example of the error message is as follows:
%BGP-4-BGP_LABELS_NOT_SUPPORTED: BGP neighbor 2001:DB8:1::2 does not support sending labels
yes its  ios version 15
what can i do to solve ,
the solution would be to remove the 'neighbor IPv6-address send-label' command, provided you have that configured. If you do not have the command explicitly configured, it could be applied through a template. What is the output of 'show sdm prefer' ?
I need to let 6PE working
to avoid confusion, can you post the configuration of your router ?
if having multiple topology for ipv4/ipv6 , how can i send label to ipv6 neighbor ( 128 bit format) while i m getting the below errors
thanks
check the BGP neighbor f label advertising has been enabled:
show ip bgp neighbors
Check for this line:
ipv4 MPLS Label capability: advertised
