L (local route) Eliminates the multicast PHANTOM RP
jacob shriki
hi all,
i have a problem regarding multicast bidir redudency RP.
as we know the redudency RP with bidir is created by the PHNTOM RP-
"The  preferred  method  for providing  Bidir  rendezvous  point redundancy  can  be   designed  using
loopback networks with  different mask  length . This  mechanism  relies  on  unicast  routing  longest
match  route  lookups to guaranteea  consistent  path  to  the  rendezvous  point"
in the new IOS  image (I.E router 3945), when we create a loopback, the router will install L route (which is host /32 route).
beacause of the /32 route the PHANTOM RP can not work properly.
R1_BACKUP_RP# interface Loopback2
description RP_address
ip address X.X.200.1 255.255.255.0
ip pim sparse-mode
R1_BACKUP_RP#sh ip route
L       x.x.200.1/32 is directly connected, GigabitEthernet0/1
the x.x.200.1/32 address is the ip of the master RP but beacuse of that L route
the pim can creat the shrade tree as it should.
anyone can verify?
CCIE#36456
CCIE#36456
AJ Cruz
Level 3
Level 3
https://supportforums.cisco.com/docs/DOC-16385
I don't see a way around it.
