L2 Etherchannel over 2 ISPs between two sites
dvrizhov
We are implementing the network design between the two sites (OLD Data center and NEW Data Center), scheme in attachement.
We have chosen this scheme on the following criteria:
- A single IP network between the sites (for simplicity migration);
- Fault tolerance via different ISPs.
But the problem is L2 etherchannel doesn't work correctly:
when one side port is shutting down, on the other side etherchannel will not rebuild and does not see that link down on the other end.
We have tried to use LACP in etherchannel (mode active on ports), but result was the same.
What may be the problem? Is it on the ISPs side?
Should we use this design or we have to subneting the network and make connections between the data centers classically with L3 channels and OSPF?
The configures of Core ports listed below:
OLD data center core (Cat 6509):
interface GigabitEthernet2/6
description #### TO DATA-CENTER core 1#####
switchport
switchport trunk native vlan 5
switchport mode trunk
logging event link-status
logging event trunk-status
logging event bundle-status
speed 100
duplex full
udld port aggressive
channel-group 2 mode on
end
interface GigabitEthernet2/7
description #### TO DATA-CENTER core 2#####
switchport
shutdown
speed 100
duplex full
end
interface Port-channel2
switchport
speed 100
duplex full
end
NEW data center core (Stack 2x3750):
interface GigabitEthernet1/0/1
description -- to MC-16R2-Core, port gi 2/6 --
logging event spanning-tree
speed 100
duplex full
channel-group 1 mode on
end
interface GigabitEthernet2/0/1
description -- to MC-16R2-Core, port gi 2/7 --
shutdown
speed 100
duplex full
end
interface Port-channel1
description ### to MC-16R2-Core ###
speed 100
duplex full
end
I would be grateful for any advice.
Ivan Krimmel
Level 7
Level 7
Hi Dmitry,
I couldn't open the .vsd file, so I will just give it a try - I think having a L2VPN in that case would be beneficial, as you are trying to bridge two disperse segments via a 3d-party carrier.
HTH,
Ivan.
