L2TPv3 tunnel not formed
nimmi.phasil
Hi ,
Im creating L2TPv3 tunnels between ASR 1001X and 1841,2811,3725.
Tunnels between ASR1001X and 1841 , ASR 1001X and 2811 area formed. But it is not established between ASR1001X and 3725.
ASR 1001X logs
LAB-ASR1001X-R4# sh xconnect all
UP pri ac Gi0/0/4.4:4(Eth VLAN) UP l2tp 10.10.10.3:3 UP
UP pri ac Gi0/0/4.5:5(Eth VLAN) UP l2tp 10.10.10.2:2 UP
DN pri ac Gi0/0/4.60:6(Eth VLAN) DN l2tp 10.10.10.4:6 DN
LAB-ASR1001X-R4#
*Jun 8 01:15:24.908: Xconnect L2TPv3[10.10.10.4, 6]: TUN open in <80 secs
*Jun 8 01:16:35.972: Xconnect L2TPv3[10.10.10.4, 6]: FSM RstrtDmp in LsbR, Noop
*Jun 8 01:16:35.972: Xconnect L2TPv3[10.10.10.4, 6]: TUN open 10.10.10.10->10.10.10.4
*Jun 8 01:18:18.863: Xconnect L2TPv3[10.10.10.4, 6]: TUN FAILED 10.10.10.4
*Jun 8 01:18:18.863: Xconnect L2TPv3[10.10.10.4, 6]: SOC 8F00000E/- disc-from-app: Tunnel failed to 10.10.10.4, consecutive fail count 44
*Jun 8 01:18:18.863: Xconnect L2TPv3[10.10.10.4, 6]: FSM TunClose in LsbR, TunCl
*Jun 8 01:18:18.863: Xconnect L2TPv3[10.10.10.4, 6]: FSM TunOpenD in LsbR, TuOpD
*Jun 8 01:18:18.863: Xconnect L2TPv3[10.10.10.4, 6]: TUN open in <80 secs
*Jun 8 01:19:37.886: Xconnect L2TPv3[10.10.10.4, 6]: FSM RstrtDmp in LsbR, Noop
*Jun 8 01:19:37.886: Xconnect L2TPv3[10.10.10.4, 6]: TUN open 10.10.10.10->10.10.10.4
*Jun 8 01:19:44.886: Xconnect L2TPv3[10.10.10.4, 6]: TUN FAILED 10.10.10.4
*Jun 8 01:19:44.886: Xconnect L2TPv3[10.10.10.4, 6]: SOC 8F00000E/- disc-from-app: Tunnel failed to 10.10.10.4, consecutive fail count 45
*Jun 8 01:19:44.886: Xconnect L2TPv3[10.10.10.4, 6]: FSM TunClose in LsbR, TunCl
*Jun 8 01:19:44.886: Xconnect L2TPv3[10.10.10.4, 6]: FSM TunOpenD in LsbR, TuOpD
*Jun 8 01:19:44.886: Xconnect L2TPv3[10.10.10.4, 6]: TUN open in <80 secs
*Jun 8 01:21:03.754: Xconnect L2TPv3[10.10.10.4, 6]: FSM RstrtDmp in LsbR, Noop
*Jun 8 01:21:03.754: Xconnect L2TPv3[10.10.10.4, 6]: TUN open 10.10.10.10->10.10.10.4
*Jun 8 01:22:51.654: Xconnect L2TPv3[10.10.10.4, 6]: TUN FAILED 10.10.10.4
*Jun 8 01:22:51.654: Xconnect L2TPv3[10.10.10.4, 6]: SOC 8F00000E/- disc-from-app: Tunnel failed to 10.10.10.4, consecutive fail count 46
*Jun 8 01:22:51.654: Xconnect L2TPv3[10.10.10.4, 6]: FSM TunClose in LsbR, TunCl
*Jun 8 01:22:51.654: Xconnect L2TPv3[10.10.10.4, 6]: FSM TunOpenD in LsbR, TuOpD
*Jun 8 01:22:51.654: Xconnect L2TPv3[10.10.10.4, 6]: TUN open in <80 secs
*Jun 8 01:24:05.687: Xconnect L2TPv3[10.10.10.4, 6]: FSM RstrtDmp in LsbR, Noop
*Jun 8 01:24:05.687: Xconnect L2TPv3[10.10.10.4, 6]: TUN open 10.10.10.10->10.10.10.4
Router3725 logs:
IDRBT_DC_R1_3725#sh xconnect all
DN ac Fa0/0.60 6(Eth VLAN) UP l2tp 10.10.10.10:6 DN
Logs
*Oct 10 10:42:00.271: XC L2TP: uid:16[10.10.10.10/6] Event <Connect Timer Expired>, state Waiting for timer to connect - > Connecting
*Oct 10 10:42:00.271: XC L2TP: uid:16[10.10.10.10/6] L2TUN socket session connect requested
*Oct 10 10:42:30.279: XC L2TP: Received L2TUN socket message <CDN - Session Disconnected>
*Oct 10 10:42:30.279: XC L2TP: uid:16[10.10.10.10/6] Event <CDN - L2TUN Socket Session Disconnected>, state Connecting - > Connecting
*Oct 10 10:42:30.279: XC L2TP: uid:16[10.10.10.10/6] Event <Start Connect Timer>, state Connecting -> Waiting for timer to connect
*Oct 10 10:42:30.279: XC L2TP: uid:16[10.10.10.10/6] with 50% jitter
*Oct 10 10:42:36.687: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/0 (not half duplex), with LAB- 3850-R4 GigabitEthernet1/0/33 (half duplex).
*Oct 10 10:43:03.015: XC L2TP: uid:16[10.10.10.10/6] Event <Connect Timer Expired>, state Waiting for timer to connect - > Connecting
*Oct 10 10:43:03.015: XC L2TP: uid:16[10.10.10.10/6] L2TUN socket session connect requested
Nimmi
Philip D'Ath
If you are sure the 3725 has a similar config to the working 1841 then I would try upgrading the 3725 IOS to a gold star software version.  You may just be facing an IOS bug.
Yes, the  config is similar. Version is Version 12.4(15)T4,
