L3 DHCP server problem?
thomas-renny
I my office i have Cisco L3 switch C3560v2-24TS, also act as DHCP server.
some times when users try to connect to the network, DHCP server not assigning IP address to the clients (not everybody but some of the users).
Please help me to solve this issue. DHCP 1-199.
Hello
Can you post your config of the router
When you say it doesn't affect all users- is it the same users in the same area or different users every time?
Res
Paul
Kind Regards
Paul
azzour_main#sh run
Building configuration...
Current configuration : 6675 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service sequence-numbers
hostname azzour_main
boot-start-marker
boot-end-marker
enable password vkfkd!0901
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
no ip domain-lookup
no ip dhcp use vrf connected
ip dhcp excluded-address 172.23.47.201 172.23.47.254
ip dhcp pool GSdhcp
   network 172.23.47.0 255.255.255.0
   default-router 172.23.47.254
   dns-server 165.243.39.17 195.226.228.74
   lease 3
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
description Mail_M(249)
switchport access vlan 372
switchport mode access
interface FastEthernet0/2
description Mail_B(248)
interface FastEthernet0/3
description VOIP#1(241)
interface FastEthernet0/4
description VOIP#2(242)
interface FastEthernet0/5
description Eworks_SVR
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
description L2_1
interface FastEthernet0/14
description L2_2
interface FastEthernet0/15
description L2_3
interface FastEthernet0/16
description L2_4
interface FastEthernet0/17
description L2_5(Training Room)
interface FastEthernet0/18
description UPS MGM
interface FastEthernet0/19
description File S/V
interface FastEthernet0/20
description # TMS Mgmt #
speed 100
duplex full
interface FastEthernet0/21
interface FastEthernet0/22
description # TMS Mirroring #
speed 100
duplex full
interface FastEthernet0/23
description # Internet RTR #
bandwidth 10240
interface FastEthernet0/24
description # Biz RTR #
bandwidth 1024
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
interface Vlan372
ip address 172.23.47.254 255.255.255.0
interface Vlan373
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 172.23.47.252 name Internet
snmp-server community infogs RO
control-plane
banner motd ^CCC
Access to this computer system and associated network, computer
resources, or data is restricted to those authorized by GS E&C. This
computer and related networks, resources or data may only be used
for business purposes of GS E&C and its customers.  Use by unauthor-
ized individual or for an unauthorized purpose is a violation of
LG CNS Security Policy. Violators will be prosecuted.
^C
line con 0
line vty 0 4
password ******
login
line vty 5 15
password *********
login
end
Renny,
I do not want to intrude into Paul's line of answering but after a short review of your configuration, these are two my suggestions:
  • Lower the DHCP lease time from 3 days you currently have to something considerably shorter, say, 30 minutes. Use the lease 0 0 30 command in your DHCP pool to accomplish this. This will allow for quicker reuse of your IP addresses.
  • Try using the spanning-tree portfast default global configuration command to declare all access ports as PortFast ports by default. This will allow the station to obtain its IP address more rapidly, without needing to wait over 30 seconds after it is first connected to a port.
Best regards,
Peter
