L3 ether channle?
rohitk
What is L3 ether channle?
Thanks in advance for reply
bmckenzie
So, instead of having layer 2 etherchannel where the ports included are layer 2 switchports, the Layer 3 Etherchannel is when you actually put a layer 3 address on the port channel interface so it gives it layer 3 functionality.
Usage Guidelines
For Layer 2 EtherChannels, you must configure the channel-group interface configuration command, which automatically creates the port-channel logical interface. You cannot put Layer 2 interfaces into a manually created port-channel interface.
You create Layer 3 port channels by using the interface port-channel command. You must manually configure the port-channel logical interface before putting the interface into the channel group.
Only one port channel in a channel group is allowed.
So, Can I use L3 ether channel on 7200 Router?
Hi Rohit
You will be able to configure Port channel which is otherwise called as Ether Channels on your router.
do check the link for more info..
http://www.cisco.com/en/US/partner/tech/tk389/tk213/technologies_configuration_example09186a0080094958.shtml
regds
