LAB SETUP QUESTIONs???
Charlie Mayes
I am trying to setup a lab for the CCNP2 ISCW. I am trying to run the c2800nm-advipservicesk9-mz.124-10.bin IOS and need to know what model 2600XM router I need to run this software. I also need to know what is the minimum Flash and Ram I need to make this happen. Thanks.
satish_zanjurne
Level 4
Level 4
To run image "c2800nm-advipservicesk9-mz.124-10.bin" you need to have Cisco 2800 series router like 2811 which has NM slot.
You cannot run IOS for Cisco 2800 on Cisco 2600XM.
HTH...rate if helpful..
