Lacp
saquib.tandel
Hi, my setup is
vlan 10
vlan 11
Port fa 0/9 and Fa 0/10 connects to Primary Barrcuda LoadBalancer
Port fa 0/11 and fa 0/12 connects to Secondary Barrcuda LoadBalancer
interface fa 0/9
switchport mode access
switchport access vlan 10
interface fa 0/10
interface fa 0/11
switchport access vlan 11
interface fa 0/12
I want to configure Link aggregation using LACP on CatOS,
fa 0/13-16 for vlan 10
fa 0/17-20 for vlan 11
How do i ensure no looping occurs.
Hello Saquib,
all ports in slot 1 will use LACP this is a known limitation of CatOS.
LACP is standard based and should be preferred over PAGP
Hope to help
Giuseppe
8 Replies 8
Giuseppe Larosa
Hello Saquib,
you need to set the use of LACP at linecard level with:
set channelprotocol lacp ?
                        module(s)
set channelprotocol lacp x
set vlan 10 x/13-16
set vlan 11 x/17-20
set port channel x/13-16  M
set port channel x/17-20 N
where M and N are integers channel group numbers must be unique and not used already, x is the slot number
Edit:
I did a mistake
the command is different
set port lacp-channel x/13-16  M mode active
set port lacp-channel x/17-20 N mode active
as described in:
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094470.shtml
Hope to help
Giuseppe
hi, show module gives output
sh module
Mod Slot Ports Module-Type               Model               Sub Status
1   1    48    10/100/1000BaseT Ethernet WS-X6748-GE-TX      yes ok
2   2    24    24 port 1000Base FX       WS-X6724-SFP        yes ok
5   5    2     1000BaseX Supervisor      WS-SUP720-BASE      yes ok
15  5    1     Multilayer Switch Feature WS-SUP720           no  standby
6   6    2     1000BaseX Supervisor      WS-SUP720-BASE      yes standby
16  6    1     Multilayer Switch Feature WS-SUP720           no  ok
set channelprotocol lacp 1   ( 1 is the module numer for ethernet module )
set vlan 10 1/13-16
set vlan 11 1/17-20
set port lacp-channel 1/13-16  1 mode active
set port lacp-channel 1/17-20 1  mode active
is this config correct
Hello Saquib,
to build two different groups you need to use two different number like:
set port lacp-channel 1/17-20 2  mode active
Hope to help
Giuseppe
Hi Giuseppe, thanks for supporting the post.
I m confused, do I need One Channel-Group or Two for my requirment.
which command will show bandwidth utilization on the EtherChannel and data_transfer on the Ethernetchannel.
Hello Saquib,
you are going to two different devices so you need to use two groups
to be investigated
Hope to help
Giuseppe
Hi Giuseppe
Thank you for replying. Its clear that I need to have two groups.
Once I apply LACP on mod 1 then all interfaces in mod 1 will be LACP ( 48 port 10/100/100 module )  ; or its possible to use some port in future for PAGP
ST
Hello Saquib,
Hope to help
Giuseppe
Ganesh Hariharan
Hi, my setup is
vlan 10
vlan 11
interface fa 0/9
interface fa 0/10
interface fa 0/11
interface fa 0/12
Check out the belwo linkfor lacp configuration on cat os switches
and you are configuring etherchannel between load balancers port and switch it will increase the channel pipe between swicthes and load balancer.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
