Lan
tetway123
Hi guys
What cause the CPU to max out on the cisco switch and how to check whats maxing it out
Mark Malone
Hi there is hundreds of processes operating on a switch it could be any of them that jam up or there that high for a reason overloading the device etc , when your facing a high cpu you need to catch it live
Use the command ....show proc cpu sorted | I ex 0.00
This will show you what processes are the highest and then you go from there
You can also run EEM scripts to catch it all for you when a cpu hits a certain percentage , this will push a text file to flash with all the info required to see what's happening
event manager applet High_CPU
    event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.4.1 get-type exact entry-op ge entry-val "70" exit-time 10 poll-interval 5
    action 0.1 syslog msg "CPU Utilization is high"
    action 0.2 cli command "enable"
    action 0.4 cli command "show log | append flash:CPU_Profile.txt"
    action 0.5 cli command "show process cpu sorted | append flash:CPU_Profile.txt"
    action 0.6 cli command "show interfaces | append flash:CPU_Profile.txt"
    action 0.7 cli command " show ip cef switching stat | append flash:CPU_Profile.txt"
    action 0.8 cli command " show ip traffic | append flash:CPU_Profile.txt"
    action 0.9 cli command " show int switching | append flash:CPU_Profile.txt"
    action 1.0 cli command "no event manager applet High_CPU"
    action 1.1 cli command "end"
*Please rate helpful posts*
