Latency Bench mark
catalystexpress
Hi All,
Recently i did a pathping test in my network and got some crazy results, so not sure if my interpretations is correct, would appreciate if some one could help me on this ...thanks in advance
our network is on flat structure,
Test 1.  did pathping/traceroute from user desk to reach a server from singapore to london it shows 196ms
Test 2. did same test but connected the laptop to the core and result was too good for us 9ms
please refer to the attached slide which i have explained with my understanding of how to interpret the traceroute/pathping results
I assume 196ms would be the normal latency from SG to London,  offcourse it would be better if we can make it more speeder
can you plese share how you all do a benchmark for calculating the latency
thank you
keep well
cheers...
johnlloyd_13
Level 9
Level 9
hi,
your latency of 196 ms from singapore to london should be acceptable.
i assume your running VPN for both ends. i would suggest performing ping/traceroute using public IPs to get your latency figures.
to do benchmark, you can use a public traceroute or better if you can find a public router (looking glass) in singapore. see useful URL and sample traceroute captured from STIX to a public DNS server in UK:
http://www.traceroute.org/#Singapore
http://www.stixlg.singtel.com/open/public/lgmain/lgquery/
Query Results
Print
202.147.39.130
Orchard, SG Router traceroute to 212.50.160.100:
Query Request Start Time: 2011-12-08 14:40:54
Query Request End Time: 2011-12-08 14:41:16
traceroute 212.50.160.100
Tracing the route to cachedns1.core.kcom.com (212.50.160.100)
1 203.208.155.2 20 msec 0 msec 0 msec
2 ge-0-1-2-0.sngc3-dr1.ix.singtel.com (203.208.172.117) 4 msec
ge-4-0-0-0.sngc3-cr1.ix.singtel.com (203.208.172.153) 0 msec
ge-0-1-2-0.sngc3-dr1.ix.singtel.com (203.208.172.117) 0 msec
3 203.208.153.241 4 msec
203.208.171.197 0 msec 0 msec
4 so-3-0-3-0.loncl-cr1.ix.singtel.com (203.208.151.238) 196 msec
so-3-0-2-0.loncl-cr1.ix.singtel.com (203.208.153.18) 193 msec
203.208.166.181 [MPLS: Label 433280 Exp 0] 24 msec
5 203.208.152.77 204 msec
203.208.153.73 192 msec
203.208.166.45 [MPLS: Label 488402 Exp 0] 196 msec
6 ge-3-0-2.er10.the.ipc.kcom.com (195.66.226.119) 188 msec
203.208.173.85 200 msec
ge-3-0-2.er10.the.ipc.kcom.com (195.66.226.119) 192 msec
7  *
203.208.153.97 188 msec 188 msec
8 ge-3-0-2.er10.the.ipc.kcom.com (195.66.226.119) 192 msec *  *
9  ?  ?  *
10  ?
Thank you John,
The EVPN (Ethernet VPN) is a private network by Singtel we have 5Mb link, what puzzles me is when i can get 9ms ... this is super fast and do not think my link is that good ...
thank you
keep well
cheers..
