OSPF, EIGRP and BGP
ssweehinlew
For OSPF, how the network from different area and autonomous system ID connect to each other?  Apart from tunnel, is there any other way?
How about EIGRP and BGP?
8 Replies 8
You mean between different area and different proccess ID ??
Simply redistribue OSPF process into each other.
Smitesh
Yes. May I know howv to redistribute the OSPF process into each other? Can show me example? I need to know that concept.
If your Topo is something like R1 -- Area 1 --- R2 --- Area 2 --- R3.
router ospf 10
redistribute ospf 20 ?
  match        Redistribution of OSPF routes
  metric       Metric for redistributed routes
  metric-type  OSPF/IS-IS exterior metric type for redistributed routes
  route-map    Route map reference
  subnets      Consider subnets for redistribution into OSPF
  tag          Set tag for routes redistributed into OSPF
  vrf          VPN Routing/Forwarding Instance
HTH,
Smitesh
Hi Ssweehinlew,
If you want to redistribute from one process into another you can do something like:
router ospf 1
  network 10.10.10.0 0.0.0.255 area 0
  redistribute ospf 2 subnets
router ospf 2
  network 10.10.20.0 0.0.0.255 area 0
  redistribute ospf 1 subnets
Is this what you wanted or was it something else you were looking for?
You must be very  careful however if you have more than one router doing this,  as without careful filtering you could end up redistributing a  redistributed route and end up in a routing update loop, which could  cause major routing issues.
Hope that helps,
Nick
See the below link for the same scenario.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00801069aa.shtml
When reditributing between different OSPF processes in multiple points on the network, it is possible to get into situations of subobtimal routing or even worse, a routing loop. To prevent this you need to you need to make the routes learned via OSPF 1 will always be preferred over external routes redistributed from OSPF 1 into OSPF 2
Please rate the helpfull posts.
Naidu.
Hi Naidu,
Yes, one must be preferred over the other, but you also have to prevent re-redistribution...
e.g.
router ospf 1
  redistribute ospf 2 subnets tag 2 cost 1000 route-map NOTAG_1
  distribute-list route-map NOTAG in
router ospf 2
  redistribute ospf 1 subnets tag 1 cost 1000 route-amp NOTAG_2
route-map NOTAG_1 deny 10
  match tag 1
route-map NOTAG_1 permit 20
route-map NOTAG_2 deny 10
  match tag 2
route-map NOTAG_2 permit 20
route-map NOTAG deny 10
  match tag 1 2
route-map NOTAG permit 20
Nick
Hi Nick,
I am not sure about that, what I did exactly is as per the link I have provided in my post and it is working as desired.
Ssweehinlew, implement as suggested and come back to us if you face any trouble.
Naidu.
Hi Naidu,
It depends greatly upon the subnets that are in use, their source (external / internal etc) and also if you are doing any summarisation.  For example if you have a summary route from one AS which happens to mask a route in the second AS, you can end up in a right mess without distribute and redistribute filters.
If your network is nice and clean, you can probably get away with just prefering one over the other - then the re-redistribution protection comes from tha fact that a route that you redistributed wouldn't make its way into your RIB.
Every network is different of course :-)
Nick
