Layer 2 switch Security
network_team
Hi is it possible to configure a layer two switch with security i.e ACL and QOS
5 Replies 5
Farrukh Haroon
Yes, why not.
Which switch exactly?
Farrukh
HI, [Pls RATE if HELPS]
Please find the attached useful Documents.
Let us know the Switch Model ?
PLs RATE if HELPS
Best Regards,
Guru Prasad R
Hi what i want to do is a link two sites together using 3550SMI layer 2 switch, but i only want the remote site to connect to some enviroments and block them to others
Please have a look at the following link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_see/configuration/guide/swacl.html
Please make sure you understand the 'login' of VLAN access-maps before you implement them, or you could end up denying legitimate traffic.
Make sure you put 'action forward' in your second sequence number (After doing 'action drop' for the desired traffic....in the first sequence number).
Farrukh
You might also find the following link useful, at least to help understand the flow/logic:
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_example09186a0080470c39.shtml
Farrukh
