Layer 3 Switch - Unable to Access The Internet and Switches
mfrank1976
Hello:
I have an SF 300-08 switch with three V-LANs assigned to it.  One is dedicated to the management of the device and the others are development boxes.
Right now, to access the switch, I have to go into the TCP/IP properties and assign a subnet within VLAN1 (subnet linked to the management interface).  Then to access the interent, I simply remove the settings, as I have another VLAN linked to a subnet from my router.
Is there a way to configure the switch that allows the ability to access both without configuring the TCP/IP settings to be on the other subnet?  I do not think so, but it is worth a try.
- Mike Franklin
jason.henderson
http://www.cisco.com/en/US/products/ps10898/prod_maintenance_guides_list.html
Is the switch in Layer 3 mode?  Can you post a rough diagram of the current setup and the IP addresses configured on the switch and router?
Also, what are you using as your default gateway on your pc?  Is it an IP address on the router or switch?
Jason
mfrank1976
The question has already been answered.
- Mike Franklin
