LDAP Application not working with 2811 IOS 12.3(8)T11
sivakondalarao
We are having LDAP application problem with 2811 router running 12.3(8)T11 image.
Before this application worked with 2621 router running 12.2(4)T3 and 12.1(5)T12
Note: There is no LDAP Query configuration in router, for LDAP just it pass through (it will do normal packet routing, configuration attached for reference).
Now we are hearing different suggestions from different people.
1 Some people are saying that "This LDAP application will work only with 12.1 and 12.2"
2 Some people saying that "It works only with 26xx series router".
3 Some people recommending to upgrade to latest IOS in 12.3 or 12.4 series.
I am requesting all technicins to put some comments on it.
Sivakondala Rao
Jon Marshall
Does the router function normally for other traffic. If it is and you are merely routing the ldap traffic then it should make no difference which router you use. So this would point to other issues. Looking at your config 2 things jump out
1) NAT
2) access-lists
Could you send more details on source IP address and destination IP address and which direction on the router the ldap traffic flows.
Jon
