LDP Neighbors
John Blakley
All,
I have a lab set up in GNS with a few routers. I have a single LSR that refuses to show neighbors:
R8#sh mpls ldp neigh
R8#
I have bindings on that router though:
R8#sh mpls ldp bindings
  tib entry: 3.3.3.3/32, rev 16
        local binding:  tag: 19
  tib entry: 7.7.7.7/32, rev 20
        local binding:  tag: 20
  tib entry: 8.8.8.8/32, rev 18
        local binding:  tag: imp-null
  tib entry: 9.9.9.9/32, rev 10
        local binding:  tag: 16
R8# sh mpls interfaces
Interface              IP            Tunnel   Operational
FastEthernet0/0        Yes (ldp)     No       Yes
FastEthernet0/1        Yes (ldp)     No       Yes
FastEthernet1/0        Yes (ldp)     No       Yes
All of my routes are going out as IP though:
tag    tag or VC   or Tunnel Id      switched   interface
16     Untagged    9.9.9.9/32        0          Fa1/0      10.89.89.9
17     Untagged    10.79.79.0/24     0          Fa1/0      10.89.89.9
       Untagged    10.79.79.0/24     0          Fa0/1      10.78.78.7
18     Untagged    10.37.37.0/24     0          Fa0/1      10.78.78.7
       Untagged    10.37.37.0/24     0          Fa0/0      10.38.38.3
19     Untagged    3.3.3.3/32        0          Fa0/0      10.38.38.3
20     Untagged    7.7.7.7/32        0          Fa0/1      10.78.78.7
       Untagged    7.7.7.7/32        0          Fa0/0      10.38.38.3
Is there anything that I can look at in particular? Shouldn't I see a neighborship with other routers as long as the interfaces connect and have 'mpls ip' enabled on them?
Thanks!
HTH, John *** Please rate all useful posts ***
Jon Marshall
John
Is this a PE or P router ? If PE router are you using loopback for peering to other PEs ?
Jon
Jon,
I guess it would be a PE router considering the external connection to an ISP. It's R8 in the attachment. R8 connects to the ISP. I run bgp between ISP and R8, and ospf on the inside interfaces. There's no nat at the moment, but I was natting earlier during another test.
Thanks!
John
Jon,
I got it  You pointed me in the right direction..the simplest questions sometimes:
R8#sh mpls ldp neighbor
    Peer LDP Ident: 9.9.9.9:0; Local LDP Ident 8.8.8.8:0
        TCP connection: 9.9.9.9.18017 - 8.8.8.8.646
        State: Oper; Msgs sent/rcvd: 14/13; Downstream
        Up time: 00:00:20
        LDP discovery sources:
          FastEthernet1/0, Src IP addr: 10.89.89.9
        Addresses bound to peer LDP Ident:
          10.89.89.9      9.9.9.9         10.79.79.9      172.92.92.2
    Peer LDP Ident: 10.79.79.7:0; Local LDP Ident 8.8.8.8:0
        TCP connection: 10.79.79.7.22639 - 8.8.8.8.646
        State: Oper; Msgs sent/rcvd: 13/12; Downstream
        Up time: 00:00:19
          FastEthernet0/1, Src IP addr: 10.78.78.7
          10.37.37.7      10.78.78.7      10.79.79.7      7.7.7.7
    Peer LDP Ident: 3.3.3.3:0; Local LDP Ident 8.8.8.8:0
        TCP connection: 3.3.3.3.646 - 8.8.8.8.29419
        State: Oper; Msgs sent/rcvd: 13/14; Downstream
        Up time: 00:00:15
          FastEthernet0/0, Src IP addr: 10.38.38.3
I guess that if you have an external connection, then the external interfaces really need to belong to a VRF. I created an ISP vrf and put my serial interface in that vrf. Once I did that, all of my neighbors came up.
Thanks!
