leased line connection through ONT to Cisco 1841 router
Dear All,
   Please assist me to configure leased line from the ONT connection on Cisco 1841 router . there have public IPs on the interfaces fa0/0 & fa0/1.
   Please give me the ideas & configuration related to this.
Faizal
5 Replies 5
Giuseppe Larosa
Hello Faizal,
for internet access service you will need NAT
follow the link below and focus on NAT overloading
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
In practice, your WAN facing interface gets a public IP address and you can use it to translate all internal private IP addresses when accessing the internet.
In your case having two interfaces with public IP addresses you can manage to use both for subsets of internal users.
see
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml
the use of route-maps with NAT can provide the flexibility you may need.
Hope to help
Giuseppe
Dear Giuseppe,
Thank u for ur reply...
Let me work on that .But if configure each of one public IP on both interface of 1841 router  , where I wil give the LAN (inside ) IP.
My connection set up is
     External Network
              | fa0/0 (Public IP)
   1841   O
              | fa0/1  (Public IP)
firewall O
          LAN
Please kindly reply me
You use the /30 WAN IP address on FE0/0 and the public LAN IP address (/29, /28, /27 etc) on FE0/1. The same subnet should also be assigned to your FW.
Hello Faizal,
I apologize I have misunderstood your original post.
You have only one WAN link and the ISP has provided you with two public IP address blocks.
First public IP address is used on the WAN link. The second public IP address block can be used to configure a NAT pool either on the router or on the ASA according to your network diagram.
I agree that on internal LAN interface of router towards ASA you can use a private IP address subnet so that you have the second public address available for building a NAT pool.
This can be helpful if there are one or a few servers that should be accessible from the internet.
Follow the documents I have linked in my first post.
Hope to help
Giuseppe
Dear Giuseppe,
I have same situation here.
Leasdline---- ASA Firewall--- L3 switch--- L2 switch
Leasd line have two public IPs--- Wan ip and LAN ip
what will be the NAT address ?
Please send any configuration file with same scenario ???..
Please help me on this
