License install
Anukalp S
Hi, could you please confirm if after installing HSEC-K9 license on CISCO2921/K9 , is it mandatory to reload router also to activate HSEC license on device.
dinns
Hello Anukalp,
If you will install HSEC-K9 in C2921, it will not require a reboot. However if you want to disable the feature, it requires a reload same goes if you want to install and activate technology packages
https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html#53013
Thankyou, we will test it and confirm back.
