Limit Telnet Access
Pnun
I created a user account on my 1760 with a privilege level of 0. However, with this user account I can still telnet into the router and make config changes. What am I doing wrong?
Rob
Richard Burts
Rob
Some additional details would help us understand your situation better. You created a user account on the 1760 is a good start. But how do you authenticate on that router? Is it simple line authentication, is it aaa authentication with local authentication, or is it aaa authentication with an ACS server?
And how do you authenticate/control access to privilege mode? Is it local on the router, or is it via aaa with local control, or is it via aaa with an ACS server?
After you telnet into the 1760 do you then enter the enable command? And do you get prompted for the enable password? And do you input the correct enable password?
When we know these things we may be closer to an answer for you.
Rick
Rick
Thanks for your response Rick. I since have got it working. I just had to setup an "enable" password. Users can dialup to the router (local authentication), establish a PPP connection and access network resources. If the users establish a telnet session to the router, they will not be able to do anything without the enable password.
Thanks again,
Rob
