Limiting incoming bandwidth on a Cisco ASA5510
j4ckripp3r
I have a Cisco ASA5510 with two Cisco Catalyst 3560G switches plugged into it. Then I have 2 Cisco1400 Aironet WAPs plugged into the switches.
My goal is to limit incoming bandwith for two specific vlans. So users who are plugged into the switch or connected to the wifi can't go bandwidth crazy.
The rule I currently have setup on the ASA5510 is limiting internal bandwidth, I know shame on me.
So how do I setup a rule on the ASA5510 that will limit users external traffic on vlans without limit internal lan traffic?
5 Replies 5
Eugene Khabarov
Level 7
Level 7
It is simple. You can specify acl in class-map and deny to match all internal networks and match anything else.
Could you please show me an example of that.
Thanks for the help
Something like this:
access-list CLASS_MAP_ACL extended deny ip 10.0.0.0 255.0.0.0 10.0.0.0 255.0.0.0
access-list CLASS_MAP_ACL extended deny ip 10.0.0.0 255.0.0.0 172.16.0.0 255.240.0.0
access-list CLASS_MAP_ACL extended deny ip 10.0.0.0 255.0.0.0 192.168.0.0 255.255.0.0
access-list CLASS_MAP_ACL extended deny ip 172.16.0.0 255.240.0.0 10.0.0.0 255.0.0.0
access-list CLASS_MAP_ACL extended deny ip 172.16.0.0 255.240.0.0 172.16.0.0 255.240.0.0
access-list CLASS_MAP_ACL extended deny ip 172.16.0.0 255.240.0.0 192.168.0.0 255.255.0.0
access-list CLASS_MAP_ACL extended deny ip 192.168.0.0 255.255.0.0 10.0.0.0 255.0.0.0
access-list CLASS_MAP_ACL extended deny ip 192.168.0.0 255.255.0.0 172.16.0.0 255.240.0.0
access-list CLASS_MAP_ACL extended deny ip 192.168.0.0 255.255.0.0 192.168.0.0 255.255.0.0
access-list CLASS_MAP_ACL permit ip any any
class-map POLICE_CMAP
match access-list CLASS_MAP_ACL
policy-map POLICE_CMAP
class POLICE_CMAP
  police output 10000
  police input 10000
service-policy POLICE_CMAP interface
Please rate if it was helpful. "Correct answer" will be also helpful. Thank you.
Is it was what you need?
Sorry for the late reply.
What you provided is the current rules I have but that still limits internal traffic.
