Link aggregation
Dear Team,
I have two link between my head office to branch office and ospf running for routing. I wan to create a virtual link between them and both two link will work as a single link .
So how will configure for this ?
Georg Pauwen
OSPF does equal cost (over a maximum of 4 path) load balancing by default. All you need to do is configure 'ip ospf cost' with the same value on all (4 in your case) participating interfaces.
Georg has provided a good sugestion now if you want to create a etherchannel on a router you can configure:
interface Port-channel10
ip address 10.0.0.1 255.255.255.0
ip ospf 1 area 0
interface GigabitEthernet0/0
no ip address
channel-group 10
interface GigabitEthernet1/0
no ip address
channel-group 10
To verify you can use show etherchannel summary
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
