Link from 2 different ISPs
alsayed
Kindly,have a look to the attached diagram!
i have 2 wireless connection from 2 different ISPs(ISPA;ISPB)ISP A Terminate link at R1;ISPB Treminate link at R2;i want to achieve the following setup:if the first Link(ISPA)fail the second link (ISPB) TAKE OVER.R1 ITS PRIMARY;R2 ITS SECONDERY;also i want to take into my consideration the LOAD Balence and the redandancy.
How can i achieve like this setup?
10xs for ur reply
27 Replies 27
spremkumar
Level 9
Level 9
Hi Sayed
With the kinda topology you have in placei would suggest to lookout for redundancy in place instead of load balancing.
If you are not having a pool of ips on your own you can have HSRP in combination with NAT which can serve the purpose of both redundancy and access to internet.
Do refer the below link for configuring up the same..
http://www.cisco.com/en/US/partner/products/ps6350/products_configuration_guide_chapter09186a008044edaa.html
regds
Hi regds !
10xs for ur reply;
1)the above link DIDN't open need a CCO account;polz provuide another?
2)plz provise a simple config for this Situation
10xs
HI!
with nat configuration we can achieve my goal:
if the primary Link(ISPA)Goes down the 2nd Link(ISPB) WILL Take over?shoul this work?
10xs
Ali,
you will get all most all the answers from this link:
http://www.cisco.com/warp/public/619/3.html
take a look at this link for configuration:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t4/ftnthsrp.htm
regards
Devang
HI Devang,long Time!!!
10xs for ur reply;i will try this...
ALI
HI EXPERT's!
am confused here about which solution do i use
1)Statful NAT
OR
2)Static NAT in an HSRP Envirment.
Plz Help
10xs
ali,
you have two things in redundancy... one is statful and other is statless...
stateful failover is to continue active flows without interruption if the master fails over to the backup.
it means here you can have your session flow is continue even though your active will goes down...
that will be more clear by the following links:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiap_c/ch20/haiphsrp.htm
http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_750/redundgd/redndncy.htm
so its all depend your need...
regards
Devang
HI Devang!
did u check my Diagram?i want to achieve if the 1 Link from ISPA Goes Down;the 2nd link from ISPB SOULD Take care
10xs
then you can go for normal HSRP with the NAT so it will reduce the complexity with your configuration...
static nat with HSRP
HI!
R1:F0/0:10.10.100.2/24
F0/1:202.10.10.1/30(ISPA Real ip address)
R2:F0/0:10.10.100.3/24
F0/1:194.126.10.1/30(ISPB Real ip address)
How could i Config my 2 routers using SNAT With HSRP?
10XS FOR UR GREAT HELP
Active Router Configuration
interface fa0/0
ip address 10.10.100.2 255.255.255.255.0
no ip redirects
ip nat inside
standby 10 priority 105 preempt
standby 10 name HSRP1
standby 10 ip 10.10.100.n
standby 10 track Fa 0/1
ip nat inside source static/pool -----redundancy HSRP1
ip classless
ip route a.b.c.0 255.255.255.0 fa 0/1
Standby Router Configuration
interface fa0/0
ip address 10.10.100.3 255.255.255.255.0
no ip redirects
ip nat inside
standby 10 priority 100 preempt
standby 10 track fa 0/1
ip classless
ip route a.b.c.0 255.255.255 fa 0/1
ali here in ip nat command you can use the static map or nat pool whatever you are looking for... for command reference this is the link: http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087c4c.html
regards
Devang
